pacbrake and OBA
Old Feb 22, 2013 | 04:29 PM
verdesardog's Avatar
pacbrake and OBA
Ok, where's a good place to mount the compressor and air tank?
Old Feb 22, 2013 | 06:16 PM
budsowner's Avatar
Compressor used to mount on top of motor that's the new on there it lays sideways on top of motor.They usually send the brackets or did.That's the best brake you can buy.Put the tank under the bed.
Old Feb 22, 2013 | 06:25 PM
wiskeyVI's Avatar
WOW....It's sure changed since I did mine!
Not sure where you can place that thing.
If you look under the bed of the truck bed just ahead of the driver side tire, there may be room there.
That's where I have my HD compressor.
Old Feb 23, 2013 | 07:20 AM
That photo is showing two different kits, Vair with 200psi compressor and tank and the pacbrake kit without compressor.
Old Feb 23, 2013 | 07:44 AM
wiskeyVI's Avatar
Ahh, got it!
My PB has little resemblance to the original configuration it came in.
My next mod will be a big tank.
Old Feb 23, 2013 | 05:21 PM
Condor's Avatar
That sure looks familiar, I just did the exact setup as that. I mounted the tank to a piece of 6 inch channel which is bolted thru the bed and a mounting plate that holds the compressor. All this is in the pass side front corner of the bed.
Old Mar 1, 2013 | 11:39 PM
BroncoAZ's Avatar
I haven't installed my pac brake yet, but I don't want to mount the compressor on top of the motor if I can avoid it. I'm concerned about vibration damaging the compressor over time. I was looking for other locations, or possibly a larger compressor (the ARB dual one maybe) back under the bed.
Old Mar 2, 2013 | 05:25 PM
C Schomer's Avatar
I put my compressor (Viair 350C)and tank on the left/outside frame below the doors, away from exh. heat. I made a tank out of 4" CPVC and end caps. I'm going to make another tank and put it on the right side. Craig
Sandaholic
18
Aug 4, 2011 07:55 PM
HOD-ISB
Oct 13, 2009 06:40 PM
pittom
Feb 18, 2006 11:36 AM
John Rodriguez
Jan 12, 2005 08:51 AM
Big dawg
Jan 25, 2003 06:19 PM
