P0243 hat does it mean?
Old Feb 4, 2008 | 04:35 PM
Big Horn's Avatar
I loaded the SMARTY software for aftermarket turbo stock injectors for the boost fooling. I liked the way it ran and i could easily hit 40psi. After a day or so I got a CEL and a 0243 code for wastegate controller. I cleared it with my smarty and it returns right away. So I changed smarty SW back to the normal stock turbo and injectors program and it is still there. Oh ya I can no longer build boost, with either SW version, 22psi is about max but more often only about 18psi. And temps are racing with no boost to cool it out. Is my wastegate stuck open? Is this even possible with an electronicly controlled gate? Any help or ideas would be apprieciated.
Old Feb 4, 2008 | 04:40 PM
WYODSL's Avatar
bump, bump
Old Feb 4, 2008 | 05:36 PM
Big Horn's Avatar
does anyone know if the wastegate is controlled by the ecm or is it the map sensor?
Old Feb 4, 2008 | 07:17 PM
53 willys's Avatar
that code is set when the ECM detects an open or short circuit in the Wastegate solenoid circuit.
I would look at you see if you have a damaged wiring harness or connectors... then I would suspect the Wastegate solenoid..
Old Feb 4, 2008 | 08:59 PM
Big Horn's Avatar
I'll check and see if I can find anything. I did't ever mess with anything under the hood, only software but that doesn't mean that it couldn't mess with the solenoid having the extra boost pressures.
Old May 12, 2008 | 05:32 AM
Nsomniac05's Avatar
I got this code when i installed my silver 62 with mech. wastegate. does anybody make something to plug in the wastegate harness? or can i build something and just hardwire it?
thanks
street5146
Jan 28, 2008 10:34 AM
Swamp_Donkey
Feb 16, 2007 10:59 AM
spitzair
Jan 9, 2007 01:06 AM
tristan21
0
Jun 12, 2006 03:00 PM
