P0148 Code Need Help
Old Oct 15, 2014 | 08:30 AM
Scottp66's Avatar
P0148 Code Need Help-5.9 3rd gen
I have a 2007 5.9 that I need help with. I was driving home from camping pulling my camper and all of a sudden it started running really rough, I was able to limp home, and then took it to a shop in town. they said I had a bad injector, they replaced it. It ran ok for 2 days and then started running rough again.
I got the truck home pulled all the injectors cleaned them(they did have a little carbon on the tips) installed a new injector wiring harness and now the truck will start and run for about 5 minute then start running rough and die.
I borrowed a scanner that allowed us to see fuel pressure and when we first started the truck(Cold) we had about 6500 psi the longer the truck ran the lower the pressure got until after about 5 minute the pressure was at 2700 and the truck died again.
What do I try next?
Old Oct 15, 2014 | 08:58 AM
Scottp66's Avatar
More info, I took the FCA out and I did not hear anything when I shock it?? I took the one out of my sons truck, could not hear anything when I shock it either, and installed it on my truck and it does the same thing.
Old Oct 15, 2014 | 09:31 AM
railroaderone's Avatar
Have you checked the output of the transfer pump
Old Oct 15, 2014 | 09:32 AM
Scottp66's Avatar
I have not check that yet, what is the best way to do that?
Old Oct 15, 2014 | 03:30 PM
BigIron70's Avatar
Cummins Guru
Procedure for testing CP3 pump
File Type: pdf
Old Jan 18, 2015 | 01:53 PM
kingey's Avatar
Had same issue, spent a bunch swapping stuff to no avail, re torqued injectors and problem solved, took about an hour and cost nothing but a couple of beers :-)
DMS1707
Sep 1, 2017 11:41 AM
smncrst
Oct 27, 2009 09:10 PM
overdooinit
Oct 6, 2008 07:07 AM
Batts
13
Jun 2, 2006 02:35 PM
StealthRam
Sep 21, 2005 02:27 PM
