over boost code
Old Jul 7, 2008 | 04:02 PM
0lywrench's Avatar
over boost code
i have my smarty with the waste gate off and a mp-8 for boost fooling why am i still getting an overboost code?
Old Jul 7, 2008 | 04:22 PM
tritont's Avatar
because the MP-8 has to turned up passed 50% or more to complete fool. I've asked them about that and was told it should fool at any % but, not the case with mine.
Old Jul 7, 2008 | 04:34 PM
Termite 06's Avatar
I'm running into the same problem with my smarty. Shouldn't have anything to do with the MP8. I've been told it has to do with a boost sensor problem. Try to switch it with one from another truck and it may not act up again on either truck.
Old Jul 7, 2008 | 04:39 PM
tritont's Avatar
if you're boosting to between 40-44psi or more, a fooler ( MP-8 ) is required. If using the MP-8 as the fooler... it has to be turned up to do it.
Old Jul 7, 2008 | 04:50 PM
AH64ID's Avatar
The smarty alone should do enough to not throw a code, but at 44psi the ECU will defuel, no code thou.
Old Jul 7, 2008 | 04:54 PM
tritont's Avatar
the Smarty doesn't boost fool and with a fooler, you won't be defueling.
Old Jul 7, 2008 | 04:57 PM
browndg's Avatar
I had the same code this weekend, I unpluged the quad boost fooler thinking the smarty would be enough.Forgive me for hustling in, But is it okay to run both ?? ( smarty and other fooler )
Old Jul 7, 2008 | 04:59 PM
diesel69's Avatar
I Have A Smarty Tnt/r And An Ats Boost Fooler. The Smarty Says It Has A Built In Boost Fooler, But It Still Threw The Overboost Code. With The Ats Boost Fooler Also, No Overboost Codes.
Old Jul 7, 2008 | 05:01 PM
tritont's Avatar
yes, if you want to see more than the 40 to 44psi of boost, you will need a fooler whether it be the Quad, MP-8 or another. If you've gotten close to those boost levels, the ECM will throw that code without them.
The Smarty doesn't do anything the ECM can't and fooling past 44psi is one.
Old Jul 7, 2008 | 07:21 PM
0lywrench's Avatar
thx guys,so where would the boost fooler go in a quad commander,mp-8 kinda stack?1st 2nd or 3rd
JL4822
Jul 22, 2009 02:17 AM
kpeterson
Jan 14, 2007 08:22 PM
mooseman
Aug 23, 2004 08:34 PM
bigfoot
Aug 14, 2004 02:22 PM
mooseman
Jul 31, 2004 04:42 PM
