OOOOOPs
Old Dec 7, 2006 | 10:48 PM
morkable's Avatar
OOOOOPs
While installing the arps and the new injector nozzles,, we had a little mishap... broke off one of the brass parts where the wire hooks on,,, Now I am scrambling to find another injector that I can steal the top off of it
Kevin
Old Dec 8, 2006 | 08:50 AM
lmills's Avatar
Be careful when you take the top off! There is a small check ball in there.
Old Dec 8, 2006 | 07:13 PM
Luken's Avatar
I broke the little plastic divider on the top of the injector... I just spread the wires apart and tightened them down... Will that cause a problem?
Old Dec 8, 2006 | 07:30 PM
lmills's Avatar
Luken, I am scared to ask, but when did you do this and how???
Old Dec 8, 2006 | 08:19 PM
morkable's Avatar
Ok , got a new injector and put the new piece on,, and all together,, but now it wont start,, just turns over,, any ideas?
Kevin
Old Dec 8, 2006 | 08:21 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I am with you
Old Dec 8, 2006 | 08:31 PM
Luken's Avatar
Quit pickin on me guys!
It actually wasn't me... When I was putting my truck back together I tried to get the return fuel line banjo bolt screwed into the back of the head .... Anyways after 30 minutes of backache, I told my helper to get up there and try. His knee slipped and CRACK. It was 11pm and I didn't know what to do so I did what any Redneck would do. Drive it! LOL
Does it cause any problems????
Old Dec 8, 2006 | 08:38 PM
masonic-dodge's Avatar
Luken
Your injector is fine. Don't worry about it.
CRIS
Old Dec 8, 2006 | 08:50 PM
lmills's Avatar
yeh yer probably just fine. It's just a sensitive solenoid cap there that is easily damaged. No big deal. I just had one that got dropped lightly on the solenoid end enough to ding a thread on the brass threads. The results was a damaged injector that hung open and caused my engine to run off. No biggie though.
And before you ask, no I did not drop it LOL. That was how I got them from a guy on ebay.
Old Dec 8, 2006 | 08:52 PM
lmills's Avatar
Kevin
yeh, there's a good chance you probably lost the check ball I mentioned in the first post. Without it the system will not build pressure and the ECM will not call for the injectors to fire.
Luken's Avatar
Ya....... I bet
Old Dec 8, 2006 | 08:55 PM
lmills's Avatar
yeh, nothing like swinging wrenches till 1:30 AM and having the engine run off when you finally get to test fire it.
Old Dec 8, 2006 | 09:02 PM
morkable's Avatar
I am getting error code p0633 immobiliser key not programmed, would or could that have anything to do with my problem??
Kevin
Old Dec 8, 2006 | 09:19 PM
lmills's Avatar
have you ever had the code before?
Old Dec 8, 2006 | 09:21 PM
morkable's Avatar
I have been trying to remember,, I think so,, but cant remember totally for sure
Kevin
