OOOOOPs
Old Dec 8, 2006 | 09:35 PM
lmills's Avatar
Kevin, I pulled this off of another site
Ok, stopped at the dealer and showed them the code.
The tech that does codes said that this is a soft code and is only to provide history of an actual problem. The code "P0633 SKIM Key Not Programmed in PCM" means that at some point something interferred with the Key Chip starting the vehicle. This could have been anything from radio waves to sun spots.
He said that to clear the soft code would need to reset all codes and history. He said that they dont recommend this because if problems keep happenig the history stored will help determine if/when replacement of components should be done.
He said if I insist he will reset all codes. I said that I will leave it for now.
That's what I know, not sure that I learned anything.
I am thinking the 0633 most likely is not the problem
Old Dec 8, 2006 | 09:37 PM
morkable's Avatar
yeah I have been researching that too,, and I agree. But I am getting buffaloed cant seem to figure it out.
Kevin
Old Dec 8, 2006 | 09:41 PM
lmills's Avatar
Have you cracked line high pressure lines to see if you are getting fuel?
Old Dec 8, 2006 | 09:44 PM
morkable's Avatar
We have cracked them without turning it over, and there is fuel there
kevin
Old Dec 8, 2006 | 09:47 PM
morkable's Avatar
Hey Lmills, that check ball,, where exactly should it be? I have 2 injector bodies here, and I will take a look, but not sure where that check ball should actually be?
Kevin
Old Dec 8, 2006 | 09:48 PM
lmills's Avatar
when you had the injectors out, did you check to see that all of them had the copper washers on them? It really is sounding to me like the system is not building pressure. Until the pressure is high enough the ECM will not fire the injectors. So it will just keep cranking.
How long have you cranked??
Old Dec 8, 2006 | 09:50 PM
lmills's Avatar
hard to describe. if you have one, take it apart carefully and look. It is very small and the one piece is magnetized so it will stick to it. Oh yeh, I can't remember the TQ spec for the top of the injector off the top of my head, but it is also very sensitive!!!!
morkable's Avatar
all the washers are there for sure,, we have cranked quite a bit.
Kevin
Old Dec 8, 2006 | 09:52 PM
morkable's Avatar
we are going to try the check ball theory,, sounds plausable,, that check ball should be at the top I would imagine?
Kevin
Old Dec 8, 2006 | 09:54 PM
lmills's Avatar
yes and very easy to lose LOL
Old Dec 8, 2006 | 09:57 PM
morkable's Avatar
cool,, we are pulling out 2 injectors right now.. the one that we worked on, and another as a template,,, thanks for your help,, I will let you know what happens
Kevin
Old Dec 8, 2006 | 10:09 PM
morkable's Avatar
ok pulled the top off of that injector, there was a ball and a puck, in the well where the spring goes down... now what? I wish I knew more, or had maybe done this before
Kevin
Old Dec 8, 2006 | 10:11 PM
lmills's Avatar
Is the ball in the injector you had apart originally? Or in the one you were taking apart for reference?
If it is in place, I hate to ask, but have you checked the simple stuff, like the rail pressure sensor plug and injector harness?
Old Dec 8, 2006 | 10:20 PM
morkable's Avatar
yeah,, our next thought is to try hooking up everything sans extras Like juice and such
Kevin
Old Dec 8, 2006 | 10:30 PM
lmills's Avatar
Who did the nozzles? Did they make sure they did not drop anything out of the injector bodies? Also, did they TQ them properly?
