Oil Pressure
Old Aug 6, 2008 | 11:43 PM
GOT BOOST?'s Avatar
Oil Pressure
Hey guys does dipricol make an oil pressure gauge? I am getting ready for a few minor changes. For those who are running them what kind of numbers do you see? Jay
Old Aug 7, 2008 | 06:56 AM
TonyB's Avatar
DOn't know anything about dipricol.
My oil pressure runs at the following pressures:
Idle, HOT day, 200-210F Engine: 6-8psi
2500rpm, 200-210F Engine: 40-50psi
Cold start, hot day/cold day: >60psi
Winter Idle, hot engine: 10-12psi
Tony
Old Aug 7, 2008 | 09:34 AM
enafzige's Avatar
I used a 0 - 100 psi fuel pressure gauge from DiPricol, and it's been working great for 25k miles.
--Eric
Old Aug 7, 2008 | 10:00 AM
lmills's Avatar
If you are looking for a pressure range. I would recommend a 0-100 PSI gauge. I know on a cold start mine can pretty much peg that when the oil is thick. Once warmed up I run around 65 psi cruising on the interstate
Old Aug 7, 2008 | 12:11 PM
GOT BOOST?'s Avatar
Thanks guys, I guess I dont need an isolator. Where would you tap into the system? I will be running an amsoil bmk-25 remote setup to make room for the new addition(s) to the family Jay
Old Aug 7, 2008 | 12:28 PM
lmills's Avatar
tap in on the port on top of the oil filter head. They are 1/8" NPT
Power Ram 250 C
Feb 20, 2007 11:08 AM
streetsmoker
Feb 22, 2006 06:47 PM
bigragu
Jan 24, 2006 11:16 AM
CIN'S DODGE
16
Dec 5, 2005 04:14 PM
