OIL Everywhere!!
Old Nov 16, 2007 | 12:33 PM
Dodgezilla's Avatar
Or someone didn't check to make sure the old oil filter gasket came off before installing the new filter. I can tell you that makes a mess....
Old Nov 16, 2007 | 12:36 PM
ptgarcia's Avatar
But he said engine oil levels are still where they should be.
Old Nov 16, 2007 | 01:13 PM
jrussell's Avatar
It doesn't take much to make a mess. When mine leaked I could barely see a difference in the oil level.
Old Nov 16, 2007 | 01:46 PM
RamWheelsBy4's Avatar
Originally Posted by MikeyB
The NV5600 uses a 5w-30 tranny lube so it does look like engine oil.
MikeyB
Well it might look sort of the same to start with, but the engine oil on mine is coal black 30 minutes of driving. Whereas my transmission fluid looks the same as when changed after 20k miles.
Old Nov 16, 2007 | 05:25 PM
fjbiker86's Avatar
Its easy to tell if its motor oil or not. You said you drove it for a full day so that means your motor oil WILL BE jet black. So if its jet black I think you found were its comming from. If it looks like somewhat clean oil then its not from the motor.
Old Nov 16, 2007 | 06:25 PM
Kman9090's Avatar
It looks somewhat clean and it is kinda to runny to be motor oil kinda like 5w-30 oil so I am starting to lean towards tranny but it also looks like it is comming from the passenger side up top of the motor so it maybe the turbo line. Its hard to tell what it is being it was dark when I was looking at it. In some spots it looked pitch black oil and some look really clear so I don't know if it's getting dirty or not. I will figure it out this weekend hopefully.
Old Nov 18, 2007 | 06:31 PM
Kman9090's Avatar
All right got it looked at and it was the valve cover gasket. I had the valve cover off to re adjust the valves and messed up the gasket so I fifgured I'd re post and let you guys know what happened for future reference.
Old Nov 19, 2007 | 10:17 PM
lniemeyer2's Avatar
Augh! Yes, the old always check the last thing you messed with trick!
Ramdriver15
Apr 24, 2007 04:27 PM
fearthedeere
Jul 21, 2005 03:18 PM
herb
33
Feb 26, 2005 08:53 AM
CCOUGHRAN
125
Aug 18, 2004 07:23 PM
powerwagon440
Apr 29, 2003 08:53 PM
