Nitrous Question, and Mp8
Old Dec 29, 2008 | 08:46 PM
DodgeCTD's Avatar
Hey guys I'm thinking of putting the bottle on my truck. It would be used from a guy with a 2 gen dodge cummins. My question is do i have to change the timing while spraying? About how much more boost would I see spraying a small shot?
I'm also thinking about ordering the mp8 tomorrow, does it add pretty good power when stacked with smarty tnt. I have read that they stack well but it is good worth 400 dollars? Just looking for opinions here...would the mp8 really benefit me? Thanks for any replies
Old Dec 29, 2008 | 08:48 PM
DENVERDODGE04's Avatar
do you still have the TST? if you do and have rail pressure adjustment it would be a waste if you don't then it would be a good thing to have.
Old Dec 29, 2008 | 11:16 PM
DodgeCTD's Avatar
No i dont have the tst anymore...i did have the rp option but i heard it does not work as good as the mp8.
Old Dec 30, 2008 | 01:24 AM
WUnderwood's Avatar
how big a shot are you planning?
Old Dec 30, 2008 | 09:18 AM
kantdrive55's Avatar
DTR Advertiser
With Nitrous start small and work your way up. It is pretty hard to hurt a diesel with it. Think of it as turbo in a bottle. As you work your way up in jet size you go until you hear it start to "pop" or "shoot ducks" then back it down a jet size. It wouldn't be a bad idea to pull a little bit of timing out of it. You don't have to, it will just run a bit better.
The MP8 works well in a stack. I wouldn't rely on it as your only module. The extra fuel will help you to run more nitrous.
Old Dec 30, 2008 | 09:51 AM
DodgeCTD's Avatar
I'd like around 100hp...not very sure what the safe limit would be for my setup
Thanks for the info on the nitrous..as far as the mp8, I heard it helps turbo spool and helps on the bottom end which is exactly what im after. Thanks for the replies
Old Dec 30, 2008 | 10:35 AM
DTR Advertiser
You can run a 100 shot with no problems at all. You could probably run a 150 shot with the MP8.
Old Dec 30, 2008 | 02:13 PM
paulb's Avatar
I would be careful without studs.
Paul
Old Dec 30, 2008 | 02:40 PM
DTR Advertiser
Paul
If you are going to run the 150shot or bigger then definately, on the common rail you can usually get away with the smaller jet depending on how much timing you are running. Good point though....
Old Dec 30, 2008 | 03:19 PM
04DEEZELRAM's Avatar
Ill hold the nitrous bottle for ya buddy....hahaha
Old Dec 30, 2008 | 08:46 PM
12valve's Avatar
It helped quiete a bit on the 06 in my sig!
put in dual cp3s and saw between 20000 and 22000 on WOT on the rp gauge, after the mp8 at 50% i see no less then 26500 all through the quarter mile. you can feel the truck pulling harder and smoke more as you turn it up, that on a 11 sec truck. its worth every cent of the $350 we payed on ebay
Roebuck9
Aug 6, 2008 07:35 PM
Mike D
87
Apr 10, 2008 03:18 PM
hazer04
Oct 20, 2006 12:28 PM
smoky beast
28
Oct 13, 2006 01:15 PM
Igor
May 10, 2006 09:19 AM
