new trans or new truck
Old Oct 16, 2010 | 08:11 AM
Brian Lent's Avatar
Originally Posted by Raspy
Lrdchaos said it very well. Don't dream up a problem and let it dominate your thinking. However, if you want more power, you'll have to do something with the tranny.
Also, it's not just a simple matter of building it up to make it fine for towing. One big problem with the 48 RE that will never be fixed is only having 4 speeds. Another is that 1st is really high geared. This leads to slow starts and a lot of torque converter heat.
I tow a lot in the mountains and really wish I had a G56.
How about a fresh NV5600. Drive your ace to pa and I'll do the swap. I want a full built auto.
Old Oct 17, 2010 | 07:14 PM
2003Ram's Avatar
I'm having my trans built right now at a shop in Santee. Seems to be the only place in Socal that can build a performance truck tranny. My stock 48re isn't broken, but I have started to develop a shutter in the TC under load.
PM if you want more details.
Originally Posted by James Birdsong
I have a 04 2500, long bed, quad cab 4X4, with about 85,000 mi. I've recently began towing a 36' fifth wheel (about 12,000 lbs) and concerned about the transmission life. What kind of life is anyone getting from their 48re when used for towing? Am I better off to install a "beefed up trans" (at estimated $5000) or or trading off to a newer model model with the newer trans, (not the 48re)? What year has the better trans? Is it better than the after market products? Is my $5000 estimate close, in San Diego, Calif? Thanks.
Old Oct 18, 2010 | 10:43 AM
James Birdsong's Avatar
what is the name of the shop in Santee? any idea what kinda of $$$$ & what all is being done? thanks, Jim.
Old Oct 18, 2010 | 02:50 PM
2003Ram's Avatar
PM sent.
Old Oct 18, 2010 | 07:43 PM
Spooler's Avatar
All you need is a VB upgrade, Flexplate, TC, and billet input shaft. Basicaly, What you see in my signature. Installed it cost me around $3,800. Money well spent. Sure beats buying a new truck.
Old Oct 18, 2010 | 08:10 PM
2cowRanch's Avatar
Originally Posted by soulezoo
I'll say that we most often hear the problems and failures but rarely the successes.
My friend has an 06 48RE with 250K on it. It's a welding truck that has to weigh 10,000 lbs. and he often tows with it. I asked him about the transmission and he said he changes the fluid and filter every 50,000-60,000 miles. I would never go that long but my point is that it's not a bad transmission.
My 5er is 10,000 lbs. and it's done just fine. Just follow the Schedule B maintenance and tow away.
Old Oct 18, 2010 | 10:13 PM
drew03's Avatar
Talking
Originally Posted by Lrdchaos
What makes you think dodge let us down with the transmission? There are literally thousands of 48re transmissions pulling that load or more on a daily basis. Don't fall into the trap of what you read on these forums....If you add hp and tq to the mix, yes you will have issues. If you run the truck like dodge built it, you won't have any issues. Yes it doesn't run as fast, or spin the tires as easily without the extra power, but it was never intended to. Just hook up to the rv, leave it stock and pull it all over the US.
what he said
Old Oct 19, 2010 | 04:05 PM
redruM Hauler's Avatar
We are averaging 180k on stock 48's with stock motors, my old truck had stacked box'es and only got 90k, imho if you dont go nuts with the power all you ned is a converter and a shift kit (on a fresh rebuild) should cost around 2500$ if you have someone do it
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
djgaston
Oct 30, 2005 03:18 PM
Dodgezilla
Feb 22, 2005 07:03 PM
live wire
Jul 21, 2003 07:26 AM
