New Airdog design?
New Airdog design?
Has anyone put on the new Airdog pump since they changed the pickup design? Drilling through the OEM canister and using your stock pickup tube...... or something like that? I am about to order one, but would like to know if there has been any issues with them, and how in the heck it still works if your stock pump goes out????
Thanks
Jason
Thanks
Jason
Not sure. I spoke with Rich at GDP today, and talked to him about an Airdog. He said they just came up with a new fuel pickup design. Something about drilling through the top of the canister and the tube sitting in the fuel bowl. He wasn't quite sure how it worked because the way he see's it, if the stock fuel pump goes out, he didn't know how the Airdog would pick up fuel in the bottom of the tank being that the Airdog tube only sat as low as the fuel bowl. Without the stock pump working, fuel wouldn't even get to the bowl.???
. I'm not sure how even the stock pump quite works, but this is just what he told me. So don't quote me. He said he talked with Airdog and never really got a straight answer. He asked me if I would post on it and get info from guys that have used this new kit. So, here I am.
Thanks
Jason
Thanks
Jason
Thanks
I recently installed a 150 on mine and i drilled the canister lid. no problems. The stock pump does not put fuel into the canister (only returned fuel) it takes it from the canister. The purpose of the canister is to limit fuel movement around the pump and keep fuel there. My stock pump is turned off (actually i used the factory circuit to energize the airdog relay) and i have drawn my tank all the way down to a gallon or 2. One thing i will tell you though is not to use the return line setup they give with the kit. Buy an additional draw straw for in the canister. Use one for draw and one for return. The reason you want to return the unused fuel to the canister is so you dont draw all the fuel out of the canister and starve the pump (this applies for less than 1/4 tank of fuel). If you think about it these pumps are designed to move 150 gallons per hour. At that rate you can pump all the fuel out of your tank in about 12 minutes. There is no way your engine can use that much fuel that fast. All that fuel has to be put somewhere and that somewhere is returning it to the tank. The canister is not that big and can be drained quite quickly. Do some searches on here and you will find alot about it. My .02
sure. One more thing to keep in mind. take note of how far the canister head pops up when you remove the retainer. This will come in handy when you install the draw straw, since it will need to be cut to length.
kdbvulcan
20
12-06-2008 04:34 PM
