Need more smoke
Old Jul 1, 2007 | 09:00 AM
jrussell's Avatar
Originally Posted by Racing41
What bullydog or smarty do you guys recommend? Arent there different ones? I know that bullydog has the power pup, and the triple dog. I dont want to do tranny upgrades so keep that in mind. Like I said b4 I tow a 28' enclosed trailer loaded with a race car and tools and such. Do you recommend stacking or just replacing the edge ez?
I think someone already answered the stacking question. Not a good idea without a built tranny.
Looking to cover that nice 28' trailer with soot? Hope you like washing it!
Patriot2500's Avatar
I have the Power Pup with the Crazy Larry setting, and it smokes alot on the performance setting (90 hp). Just remember, that smoke is unburnt fuel, so the heavier your foot is and the more smoke you throw, the less your fuel mileage is.
JRussell, I agree with you, but it is kinda cool to blow some smoke and a tailgating car
Old Jul 1, 2007 | 09:18 AM
jrussell's Avatar
Oh, I have to agree completely there! If there's a good reason then so be it.
Old Jul 1, 2007 | 11:16 AM
Racing41's Avatar
Will a boost fooler do anything for me? I am not to sure bout this diesel stuff.
Old Jul 1, 2007 | 11:51 AM
jwb600's Avatar
ya it will get your more boost and be fairly hard on your stock turbo. its a cheap mod but I wouldnt run one forever. the only way I would run a boost fooler is if you plan to get a new turbo in the future. if you dont then dont put a fooler on it.
Old Jul 1, 2007 | 08:47 PM
own1bigtruck's Avatar
I already know im on borrowed time on my tranny. getting another isnt really an issue. However, I did just change the tranny fluid an filter yesterday. The oil came out looking and smelling like new, very little particles on the magnet in the bottom of the pan, and everything looked really clean. Even I was expecting to find quite a bit of clutch material in the pan. I did put on a Mag-Hytec double deep pan, so it will be easier to change the next time, and hopefully keep the tranny temps down while towing also.
Forgot to mention, I havent felt it slip yet either. I usually go into the throttle easy until it gets into lockup before putting the fuel to her. I may have it turned up, but I dont hot rod her. Guess at 28 years of age, I outgrew the drag race fever. Still like big power and smoke, but like someone else said, its usually reserved for a tailgater or ricer!
Old Jul 1, 2007 | 09:22 PM
vzdude's Avatar
DTR's 'Go to Guy'
A boost fooler will not GET you anymore boost as I read it. A boost fooler will allow you to run more boost without turning the check engine light on.
Old Jul 1, 2007 | 10:37 PM
Pinksa's Avatar
My understanding was the computer has a "boost limiter", therefore the fooler lets the truck build more boost. Correct me if im wrong
Old Jul 1, 2007 | 10:43 PM
vzdude's Avatar
DTR's 'Go to Guy'
You are correct on the newer trucks 04.5 and up. I didn't look at your sig. My bad! In order to get a lot more boost though, I think it takes more air and more fuel with the fooler.
Old Jul 1, 2007 | 10:46 PM
vzdude's Avatar
DTR's 'Go to Guy'
On his truck ( the original poster ) in order to get more boost, he needs to modify the wastegate. I made my own boost elbow in about 20 minutes! Couple of drill bits, and a 5/16 set screw, drill and tap the elbow and screw the set screw all the way in got me over 10 more psi of boost. You could block the wastegate hose off, but I liked the idea of being able to adjust it.
Old Jul 4, 2007 | 09:31 AM
hump's Avatar
Racing41
Well if your not wanting to do any tranny upgrades, then I would say either continue to run the Edge Ez module alone by itself or Get a BD Triple Dog and run it on the tow setting stacked with the Edge Ez on the low setting. That will give you some smoke.
Old Jul 4, 2007 | 12:35 PM
jgiachino's Avatar
Originally Posted by own1bigtruck
Ive got the smarty on my 06, with the factory programming from Mads, It only smoked a little even on #9. Now im running beta 4.4 on #9 and it hardly smokes at all. My truck has never blacked out intersections no matter how hard I have tried. What am I doing wrong??? I had great expectations on leaving a BBCOD on my buddies duramax and it let me down!
Drive 50mph on an onramp....let off the throttle.....give it 50% throttle.....it'll fog a small town...regardless of programmer, smoke occurs at heavy fuel and low boost....once the turbo spools, it'll clean up the smoke, unless you have a ton of fuel pouring in!
Old Jul 4, 2007 | 12:40 PM
jrussell's Avatar
That should do it.
Tow/Haul mode with the converter locked in 3rd gear at about 30-35mph will put out some nasty smoke too...when you punch it.
TDRattler
Jul 12, 2008 07:42 PM
BlackSheep5
Nov 27, 2006 07:52 PM
Chipper24
14
Mar 11, 2005 04:08 AM
country
Sep 29, 2003 10:22 PM
