Need less smoke with Smarty Jr.
Old May 3, 2016 | 01:28 AM
Tori's Avatar
(04.5 Auto) 90% of the trucks use is spent towing 8,000# I do get a fair amount of soot on the trailer nose which is a real PIA to keep clean. Even not towing, the truck smokes on accel. Not "rollin' coal" smoke, but enough that i can see it in the mirror. My Smarty Jr. is a couple years old, so maybe there's a update for it. Currently running (SW2-TM4-TQ2) Is there another combo i should try that would help eliminate some of the smoke ?
Also, for what it's worth,... i get really crappy fuel economy. 10.5 towing.
Old May 8, 2016 | 05:41 PM
john40's Avatar
I have my Smarty Jr (514b) set at a mild, SW-1, TM-2, TQ-4 & POD-90. Pulling our 12,000# across the U.S. (maximum speed of about 65 MPH) we averaged about 11.5 MPG. Towing, if I roll into the throttle from a stop there is little smoke, as is the same on grades under full throttle. But more important, at least to me, it lowered my EGT's 200-250 degrees.
John
Old May 8, 2016 | 06:17 PM
Tori's Avatar
Hi John, thanks for the reply. I'll try your setting and see how it treats me. I'm just up the road from you in Grover Beach, so we travel the same roads.
Old May 8, 2016 | 11:55 PM
john40's Avatar
Tori-Hi neighbor. Let me know if these settings help. John
Old Jul 7, 2019 | 08:08 PM
Tori's Avatar
Well, here i am again... 3 years later and still not satisfied with the amount of smoke i out out. Have not towed as much as i used to as late, but there is almost steady smoke even running around in town. Anyone else have a different recipe to try on the Jr. ?
Old Jul 8, 2019 | 09:41 AM
Danderson's Avatar
My '07 would begin to smoke when I drove for mileage. I had a Smarty Sr.
Occasionally I'd let the engine warm up,then make a half dozen high rpm power runs. Smoke would pour out of it.
The cat would soot up but would cleanup with this procedure. EFI has not done this as it runs cleaner by far.
You might try that.
Old Jul 9, 2019 | 09:14 AM
rockcrawler304's Avatar
I'm running the setting in my signature. Very little smoke when driving normal.
Old Jul 11, 2019 | 03:44 PM
Tori's Avatar
Thanks Rockcrawler, I may give that a try. Since my post a few days ago, i've contacted MAD's for help updating my Smarty Jr. While we were on the phone i asked for their advise. He recommended SW1, TM2, TQ2 So' i'll give that a shot. Said the TQ4 i was running could have been rough on my stock trans.
Towing later today, so will get to try it out soon.
jmccart
Jul 17, 2008 10:05 AM
greenrig
Apr 25, 2008 03:55 PM
TNLoneWolf
Oct 6, 2007 09:59 AM
Kevin Krieger
Sep 4, 2007 11:38 AM
NGM Diesel 1
Mar 15, 2007 05:28 PM
