Need Help,,,oil Leaking Everywhere
Old Feb 3, 2008 | 09:52 PM
pipeliner04's Avatar
ladies and gentleman,,,,i have a problem,,,my truck is blowin oil everywhere,,,from the oil cap,,the blow by and the oil breather,,,,i thought i fixed this problem with the oil cap once cause it was cracked,,,,so i did what anyone with common sense would do,,,get a new one,,,used 4 cans of berrymans b12 to shine her up,,,,took her for a spin,,,,same ****,,,i know its not the valve cover gasket cause i had just barely started again,,,let me know what you guys think cause im guessin scored piston,,,partially scarred piston,,,bad rings or somethin,,,if i cant figure it out after i put a new oil breather on it,,,im just gonna buy a new short block cause itll be a hell of a lot cheaper to do than a rebuild,,,gimme some input ppl,,,anythings appreciated
P.S. My 66 is MIA!!!
Old Feb 3, 2008 | 10:08 PM
drewblood's Avatar
injector making oil,or turbo seals gone bad causing blow by extremly high blow by from cyl ,those would be the first things i would check in that order
wyattearp29
Jun 24, 2010 08:32 PM
djgaston
Nov 27, 2006 02:38 PM
herb
33
Feb 26, 2005 08:53 AM
powerwagon440
Apr 29, 2003 08:53 PM
