need guage help ASAP
so I am installing my gauges today and I have almost everything done. but I started the truck up and the fan cut the EGT wires. Can I use just regular wire or does it have to be a certain length or certain type? these are auto meter gauges. thanks guys, keep those fan belts clear.
I hate being the bearer of bad news but thermocouple wire is special. The type "K" thermocouple that is used with your pyro is made from Chromel & Alumel - if you want ANY type of accuracy you'll likely have to order a new thermocouple cable. As the tip of the thermocouple is heated, it produces a very small signal [millivolt (or thousandths of a volt) range]. If you even solder or splice the wire, it will cause measurement errors due to resistance and temperature differences at the splice.
thats exactly what I was thinking was going to happen. but I just had to confirm it. no biggie. do you think I can call auto meter and just get another or will I have to order the thermocoupler and all? thanks alot Il button her up until I can order. thanks again
It was my understanding that the harness wires also had to be certin gauge and length. I think my DiPricol's said not to modifiy harness length because I guess they take into account current lose due to distance and resistance.
my .02
my .02
horselady
Jan 27, 2009 12:01 AM
stock03
Sep 30, 2008 09:03 PM
2500TurboDodge
Aug 10, 2004 10:06 PM
