Mpi
Old May 31, 2008 | 09:51 AM
mh1988's Avatar
Question Mpi
on the MPI kits i know there are different turbos you can use. I didn't wanna Pm nathan yet since im no where near close enough to getting a set yet, but if you replace both turbos would it spool faster near or better than factory? and what 2 turbos would you use on a 6 speed standard 2500 4x4 that would be a daily driver, but still tow stuff?
Old May 31, 2008 | 10:29 AM
Spooler's Avatar
Lots of reading on the subject. Just use the search function at the top of the page where you would go to User CP. Search for MPI or twins. Great reading.
Old May 31, 2008 | 10:33 AM
Matt S's Avatar
Not based on experience but on reading other's post's, twin spool up is slightly slower than the smallest turbo as a single. So if you top turbo is a 62 class then your spool up will be a bit slower with that as your top turbo instead of the 62 alone. The closest to factory would be the stocker on top.
Old May 31, 2008 | 01:47 PM
desertchecker's Avatar
depends on how much $$ you want to part with
on a budget stock/ s400 be great everyday driver/tow rig
62/65/13ss / s400 would be the kine setup for what it sounds like your looking for , but that kit will set you back a lot more
either way nathan is a good honest guy to deal with & he will set you up with something that will work good & MPI fit, finish , & performance has set the high bar in the industry for twin kits !
Old May 31, 2008 | 01:56 PM
omaharam's Avatar
I like my stocker/s400. However, I have yet to tow with it. I also expect to dyno in the upper 600s and run in the low 12s.
Old May 31, 2008 | 03:50 PM
I bet the stocker-s400 combo lights off quick .......must be a hoot to drive !
Old May 31, 2008 | 04:10 PM
Billy Ram's Avatar
Looks like you've had a lot of projects. How did the 5" exhaust turn out?
Old May 31, 2008 | 06:14 PM
omaharam's Avatar
Awsome. 3' piece of pipe off the downpipe and then a 51" donaldson and that met right up to the tailpipe. I still need to get a big ol' fat 6" tip for it though.
Old May 31, 2008 | 06:23 PM
omaharam's Avatar
With my current set up, anything under 40mph and you better have it in 4wd if you're gonna mash the throttle. For example, cruising at 30mph (where my A3k turbo would have been at no boost or only 1 or 2 psi) it is running about 10psi, so when you mash it, it GOES!!! Actually caught me off guard the first time. Smoke with the TNT maxed out and the mp8 on tells me I could have went bigger, but I wanted this set up for towing. I could probably throw a small shot of N2O on there, but I think the wife might finally put her foot down if I bring up that subject.
Old Jun 1, 2008 | 02:52 PM
sounds like a hot rod tow truck ! nice.....................
Old Jun 1, 2008 | 06:03 PM
deerezilla's Avatar
so how does the MPI stocker and s400 turbo kit tow??????????????????????????????????????????????? ???????????
jrussell
102
Aug 4, 2008 12:05 PM
RyeThomas
21
Sep 29, 2007 02:14 AM
RyeThomas
17
Sep 16, 2007 09:18 AM
RyeThomas
29
Aug 7, 2007 06:33 AM
rjm022
0
Jan 2, 2007 04:56 PM
