Sponsored by:
Sponsored by: DashLynx
mods and twins
Old 03-15-2011, 08:27 PM
randizzle's Avatar
mods and twins
hi again to all. i plan on doing twins but i have alot of work to do before i get them.
after reading a ton about what i need to support them i kinda came up with a list. my goal is to be around 650- 700hp. let me know if i missed anything
fass 150
stage 3 cp 3 or go with 2 cp 3's
smarty
fully built tranny from gorans
flux 3's or bigger
mp 8
still havent decided on what twin set up to go with
it is my dd and cant have it down too long but my buddy down the road from me has a 4 dr duly with twins with over 800 hp so i need to pick his brain a little along with him helping me tune them
i have around $13g's to spend ............so i hope i have enough lol
thanks again for the help
Old 03-15-2011, 10:15 PM
Big Dblue's Avatar
That fully built Garmon or Goerend trans is goin to set you back about 7 or 8k just to give you a heads up. plus your goin to need it with what your wanting.
But with what you have looks good as for a list. For twins start looking at a 64/480 setup.. There a few threads on here about them. Also you will need some head studs when you get those twins.
Good luck and keep us posted.
Old 03-16-2011, 08:40 AM
DTR 1st Sergeant
soulezoo's Avatar
You have a decent plan there. I made over 700 with flux 3's so you are good there. A Floor it stage 3 will support those nozzles no problem. Tranny, smarty mp-8... check. I don't see studs... you will need them. ARP 2000 is fine.
On the twin setup, I'll have to disagree with the above recommendation. It's too big for 700hp and won't be as fun to drive with the lag. Look at a 62 over s476-78. You want to fit the setup to your goal... too much extra turbo is just wasted in lag and $$$ to buy.
BD r700 twins would be perfect. There are other setups as well that support that hp range, shop around see what you like.
If you had a lot of dough, the hot ticket right now is the 62mm BW efr turbo over a Garrett gtx4508. That is good to 800+ hp and spools like crazy.
Old 03-16-2011, 06:41 PM
randizzle's Avatar
thanks for the help guys
i did forget about the studs ......i was also thinking of the 2000
as for the turbos.......... i think a 64 / 478
iv read alot of good things with them
how much more is the other set up you were talking about
is it worth getting ball bearing turbo's ?
i just want to get the right things.... sorry if i sound
Old 03-16-2011, 09:55 PM
DTR 1st Sergeant
soulezoo's Avatar
about 3x more.... :-(
Only you can decide if it is worth it for BB. It adds 50% to the cost.
if you are running the larger primary (s478), you don't need the larger secondary (64) and it just costs more and lags more.
Example 1A: bd r700's designed to keep 700 cool but can go to mid 700. it is a 57 over s476.... BD just designed them right.
Old 03-16-2011, 10:26 PM
COUNTRYBOY's Avatar
NO JOKE!!!! Boy I wished, I'd love to have that twin set up!! the prices airn't as bad as what I was expecting on those EFR turbo's and thinking hard about getting one!
Old 03-17-2011, 09:06 AM
DTR 1st Sergeant
soulezoo's Avatar
Those BW turbos only have a couple sizes useful to us right now. In some side to side comparisons, the garrett gtx series has a very slight advantage in overall power for a given size efr turbo. However, the efr turbos simply have too many features built in that the garretts do not have and that makes them the superior choice right now.
Old 03-18-2011, 03:21 PM
Big Dblue's Avatar
Like soul stated above.. the 62 as a top turbo would be better off for your goals.. a 64 is pretty big, and may have a little more lag, while a 62 will light up crazzy fast and supply the bottom charger well.
my fault on the typo.
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
Quick Reply: mods and twins
