Minimum needed rail pressure?
Old Aug 22, 2007 | 08:08 PM
cvcook's Avatar
Installing my Q- zilla r.p. gauge tonight, and would like to know what's the minimum amount of r p required in order to be making good power.
thanks, Charlie
Old Aug 22, 2007 | 08:10 PM
out4elk's Avatar
I have no idea what pressure should be but I am curious about how your installation goes. As I just mentioned in another post, I just tried to hook mine up and it is cuasing some problems.
Old Aug 22, 2007 | 08:40 PM
Megacab07's Avatar
out4elk, I have one coming. What kind of problems are you having with it?
Old Aug 22, 2007 | 09:24 PM
CReed's Avatar
Anything below 20k during a pass you are loosing power.
Old Aug 22, 2007 | 09:26 PM
OT-OF-Here's Avatar
As it happens,..
I bought two new cp3s (oem) and tested both prior to putting on my dual cp3 setup as I wanted to be darn sure they equal or as close as possible to one another for balance in the dual setup. They tested individually as follows:
Cp3 #1 = 21.7k
CP3 #2 = 21.5k
They both would fluctuate a little bit on shifts etc but those numbers are at wot. In tandem now on the dual setup they are right at 25k psi and are rock solid.
Old Aug 22, 2007 | 11:31 PM
jwb600's Avatar
my rail pressure stays at about 22k with a stage 2 pump with a smarty. when I turn the tst up the truck gets down to 15k or so and it cuts out then. dual pumps are on the list. then im going to buy huge injectors if I ever get them
5.9Excursion
Mar 13, 2008 10:56 AM
SO5.9
Jan 15, 2007 12:23 AM
rush47
15
Dec 2, 2005 03:56 PM
bigfoot
Jan 31, 2005 05:44 PM
Mechanos
Jun 27, 2004 03:38 PM
