Minimum fuel pressure?
Old Jan 14, 2007 | 08:19 PM
SO5.9's Avatar
Hey guys, this is my very first post on here because Im a brand new member. This may be a very common question for many of you. I have an 01 with 90k, injector pump appears factory, and I just installed Isspro guages. At an idle, the fuel pressure is about 7-9 psi, partial throttle is 6 psi and full throttle and boost will bring it down to 2 psi. Is this normal?
Old Jan 14, 2007 | 08:25 PM
Ram1999's Avatar
Too low.
Have you changed your fuel filter lately?
If so, it may need a new one.
My LP is the stock setup, I have 13-14 at idle, 9-10 driving normal, can get it to drop to about 5-6 WOT with a Smarty set on #9. I'm upgrading the fuel system in the spring.
You may have a weak LP or a clog in the system in the tank or fuel filter.
Old Jan 14, 2007 | 08:29 PM
SO5.9's Avatar
Originally Posted by Ram1999
Too low.
I just bought a new WIX fuel filter today and am going to install it tomorrow. Could it make that much difference?
Old Jan 14, 2007 | 08:40 PM
nitrousn's Avatar
2 psi is low. Verify your guage. Remember its all about volumn not pressure. There is a simple volumn test you can perform. I would verify the guage first. If it is correct most likely the folter is plugged or your lift pump has just about had it.
Old Jan 14, 2007 | 08:43 PM
P.J's Avatar
P.J
Yes.
BUT, so could a failing lift pump. With a health LP (and properly functioning gauge) you should see about 14.5-15.5 at idle. With no real mods, you shouldn't be able to pull it much lower than 11 or so.
Old Jan 14, 2007 | 09:06 PM
Geico266's Avatar
Where are your manners boys!
Welcome to DTR
We're glad your here. Take your shoes off, sit a while, and enjoy the show.
Trust your gage, get a FASS II lift pump to replace the stock LP.
I've tried doing a volume test doing 70 WOT, I don't recommend it. It's all about pressure and 2 psi is too low, anytime.
Old Jan 14, 2007 | 09:14 PM
dssimecek's Avatar
That is too low if the gage is correct. When my FP was first installed it read low as there was some problem at the isolator. I did not do the install myself.
Mine 11-12 idle 8-9 hwy cruise WOT5-6. Read lower on a cold morning with the grid heaters on, lo voltage. Flow test at dealer when fuel fiter was changed was full flow, filled the beaker.
What is FP when you bump the starter? Mine 13
Old Jan 14, 2007 | 09:26 PM
SO5.9's Avatar
If I bump the starter it goes to 8 psi then slowly drops. I have no isolator....the pressure is sent via diesel flowing from the injector pump to the guage with no interferences; ie. isolator
BTW, I just bought this truck out of Collinsville, OK last weekend so the history I know about it is nonexistent.
Old Jan 15, 2007 | 12:03 AM
cLAYH's Avatar
Yes thsi is normal for a 2nd gen truck. The LP system on them sucks and should be upgraded ASAP. I installed a brand new factory style pump(Delphi) 2 weeks ago. At idle I got about 16psi, with the Juice on setting 1(milage) I could pull it down to 6psi, on setting 5 I could pull it down to 1psi.
TodayI installed a Holley blue pusher pump on the frame, now I have 29psi at idle, 26 cruising and cann't get below 15psi a WOT with the Juice on 5.
Old Jan 15, 2007 | 12:14 AM
1-5-3-6-2-4's Avatar
Mine is stocker pump is rock steady at 14psi @ idle 10.5 @ WOT.
not trying to hijack here but what the most recommended psi to the pump/. I've heard of exxessive psi to the pump damaging something?!?!?! I'd going to install a walbro shortly after I get the HRVP in, but I'm not sure what to set my relief at. I've read Glacier sets all his at 17-18psi? How about 20? 25?
Old Jan 15, 2007 | 12:23 AM
Clunk's Avatar
Thumbs up
When I change my filter, I buy about a quart of diesel fuel to fill the filter housing 3/4 full after I drain the filter housing and remove the old filter. When I install the new filter on the cap and put it in the housing, a little fuel may dribble out, I just screw the filter top on and wipe up the mess. When I'm done, I turn the keyswitch just enough to "bump" the starter then quickly release it to get the Free 25 Second Lift Pump Run. After the pump quits, I start my engine.
cLAYH's Avatar
You'll be upgrading that pump once the Smarty arrieve's!
cvcook
Aug 22, 2007 11:31 PM
mj007
Dec 9, 2006 03:07 PM
rush47
15
Dec 2, 2005 03:56 PM
bigfoot
Jan 31, 2005 05:44 PM
Mechanos
Jun 27, 2004 03:38 PM
