MBRP Dealers????
Old Feb 23, 2006 | 09:33 AM
theextricator's Avatar
MBRP Dealers????
Can anyone recommend a good MRBP dealer? I am looking for MRBP muffler part #mk96116 which is a direct muffler replacement muffler for the 2005 CTDs. This muffler will fit in place of the factory one so there is no need to cut and add pipes. I just need to find a dealer that has them. This part number came directly from MRBP.
Old Feb 23, 2006 | 09:47 AM
kandgo's Avatar
http://www.dieselperformanceparts.com/
Old Feb 23, 2006 | 09:52 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
You can find them Here as well
Old Feb 23, 2006 | 10:06 AM
Cool beans Larry.......that is what I am looking for. How much louder is this particular muffler? The price is real good also.
Old Feb 23, 2006 | 10:12 AM
Admin Team Leader
It sounds much better than stock with a deep tone. They are loud outside the truck but not too bad in the cab.
Old Feb 23, 2006 | 10:42 AM
Sailpipes's Avatar
Yeah, what he said. After I put mine on, my wife said that she couldn't even tell the difference inside the cab. I noticed it because I drive it all the time I suppose. Like Top said, it gives it a deeper healthier tone.
Old Feb 23, 2006 | 10:48 AM
PimpRohr's Avatar
How many people are running their kits? and what do you think of them?
Old Feb 23, 2006 | 10:54 AM
I will be buying the muffler. I can't see wasting the money on a complete system since I already have the 4". I guess if I want to go to 5" then it would be worth it. I like the fact that the #MK96116 is a direct fit. No modifying or hacking........
Old Feb 23, 2006 | 05:52 PM
dodgestang's Avatar
www.spdiesel.com
Old Feb 23, 2006 | 05:58 PM
Booger's Avatar
I second Mark @ DPP. They sound great. Stock at idle but when you get on it, it is louder than stock. I did have to shorten the rear section of my stock tail pipe several inch's to keep it coming out in the same place. No big deal though.
Old Feb 24, 2006 | 12:56 PM
Mark Craig's Avatar
Booger,
I have been studying on how you had to cut a couple of inches off on yours, I wonder if Dodge at assembly had the system either pushed forward or backward in all the different slip joints. That could make up as much as 4 inches total length change etc???
Mark @ DPPI
Old Mar 2, 2006 | 02:37 PM
smcphc's Avatar
I also had to cut 4 inches off the rear section to get it to fit correctly. I ordered mine through DTR on Wednesday, it was here on Tuesday. Installation was more lengthy than I thought, almost three hours. I didn't have a deep socket for the Dodge u-bolts, I think it was 15mm, used a box wrench, ended up cutting off the u-bolts anyway. I used my Dremel to cut the slits in the stock muffler to get it past the dimples, also some time figuring the best way to get the rubber hangers off the brackets, it all starts to add up. Once everything was off, the MBRP slipped right in place, hangers lined up perfectly until I tried the rear section. No go, so I measured and hacksawed off 4 inches, finally everything fit and all was good. So, with proper tools and hindsight knowledge it would have gone quicker, but it's done. I'm towing a trailer from TN to WI next week, I'll see what the difference is then.
Old Mar 2, 2006 | 03:33 PM
Mark Craig's Avatar
smcphc,
That's so strange, I hear of a few like this but the majority of the go right on and you don't have to cut any extra pipe. I am starting to wonder if DC has two exhaust vendors that are doing things a little differently????
Mark @ DPPI
Old Mar 2, 2006 | 03:56 PM
smcphc's Avatar
Originally Posted by Mark Craig
smcphc,
Mark @ DPPI
My stock muffler was 38 inches from end of inlet to end of outlet pipes. The MBRP pipe/muffler is 44 inches. I measured the section of pipe I cut and it actually was 5.5 inches (I lined it up and marked it for cutting) The truck is an 04.5, perhaps some came with some weird combination when they added the cat on, maybe they needed to get rid of the remaining 04 mufflers and they fit in some strange way. So, is the correct MBRP and pipe for an 04.5+ supposed to be 38 inches or is my muffler the anomaly?
Scott
