Max boost with VA CP3.2
I don't conclude exactly what you do....
Air with out Exhaust does not help that much.
Air and Exhaust helps a bunch, but no miracles. There are other added benifits like quicker throttle response and potential small MPG increase. I did the banks pipe because I could. I spent $300 or so and in my opinion ended up with the best exhaust possible. The downpipe maybe a little over kill at this point, but may pay off more later with more power mods. I didn't want bling bling stainless under the truck that you can't even see so I did not see the benifit of buying a $400-800 exhaust. No aluminized exhaust under $400 includes a true 4" system. So with a little creativity I got exactley what I wanted for less money. The Donalson muffler has no drone (maybe a tiny grunt at 1500 rmps...but the truck is almost never at that RPM with the foot on the pedal) and really sounds nice. I am real happy with everything I have done so far...
There is a point where an exhaust system is "large enough" for a specific rig. Unfortunately, I don't know what that is. In other words, you could put a 8" exhaust system on a rig and get zero benefit over a ??? (3", 4", or?). I like the idea of the true 4" system such as you have and I will probably go the same route you have. I was just pointing out that others on this forum (most recently AKram) have seen very little benefit from the addition if the Banks downpipe. This fact shows me that the true 4" system is probably overkill for mild modification.
However, like you, I plan on adding significant power "down the road". In fact, I want to add a larger turbo very soon. At that point, I'll put a similar system on my rig as you have. When you say you spent $300, was that for the complete system including the Banks DP? If so, I'd like a parts list
Most say 4" is ideal...for 300-500 hp. I plan to try to get to 400.
I spent $200 and change for Banks BP and new 4" v-band
$100 for 6.5' of 4" aluminized pipe, donaldson muff, and three ss band
clamps from the local Stewart and Stevenson
I cut the stock system free right after the muffler where the pipe just turns 4"...bolted up the new downpipe, flared the 4" pipe at the local muffler store for nothing and sliped it on the downpipe, cut 6" or so (what ever was exactley needed to fit) off the 4" pipe, slipped the muffler in tight, tightened the three band clamps, cut off the oem hangers, rebent and welded them onto the new system where they needed to go to utilize the hangers, and presto. $300 and change, 1-1/2 hours of work. You will need a MIG welder (or TIG if you are a stud), a couple of wrenches for the downpipe and clamps, a pry bar to get everything slipped together, a cut off wheel or grinder, and a tape measure.
va duration
Originally posted by cquestad
I love it...just runs a little hot. I believe the high setting can starve the system for fuel. Have not found a hill that the mid setting can't top at 95 plus....just need to watch the EGT's. I don't think it helps with mileage at all. If I don't need the power on the highway (i.e. flat run) I turn it off. I ussually run the mid setting in town. It really makes the truck fun to drive.
I hope the rumor about a free upgrade for timing (when VA figures it out) is true. It would help with EGT's and mileage, which in my opinion is all that it needs. I might stack it with a pressure only box (40-50 hp range) in the future as soon as I control EGT's and supply enough fuel. It would really scream then...
Jethro6213
19
Jul 11, 2008 11:59 AM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
GTSDave
Jul 8, 2005 09:06 AM
belfert
Sep 9, 2004 03:23 PM
