max boost with smarty?
with my smarty on level 9 and all the basic mods I have listed in my sig I see a max boost of 38psi. Looking on this forum it seems as though many of you see more than 40psi easily with the smarty on sometimes lower levels. Is this a normal boost psi or should I be getting more boost?
I'm having the same problem but my boost is even lower. I'm barely hitting 30 or 32 psi. I could hit 42 with my quadzilla and with my banks, so I need to get this one figured out. I'd do a boost fooler, but richard at browns diesel said they picked up 20 hp when they ran the revo without the boost fooler so I don't know what to do
All that said, for your individual truck alone (not about anyone else's), I would say that is normal due to the CFM+ you have on there. A lot less restriction with that puppy. Besides, on the stock turbo you get no real benefit from anything over 40psi anyway-- it is just a lot of superheated air.
I can get 70 psi from my twins... that doesn't mean it is great air.
per Bob,
The Smarty DOES NOT boost beyond 44psi. That is what the ECM is set at regardless of the wastegate setting.
You guys seeing more.... who know why, maybe because you have the older ECM's ?? but, the Smarty is 44psi max.
A boost fooler is needed beyond that.
Hetdiesel
Aug 6, 2009 08:18 PM
GTSDave
Jul 8, 2005 09:06 AM
belfert
Sep 9, 2004 03:23 PM
fishin fever
Feb 22, 2004 08:32 PM
Zino
Aug 15, 2003 10:14 PM
