mass diesel/diesel manor tranny line
Old Apr 24, 2007 | 07:09 PM
rjm022's Avatar
mine is leaking at the fitting that came installed in the port. i need to take the whole line off, so i can take off the fitting and re-paste it,etc. does anybody know what size of a plug i would need for the top male and the bottom femalethreads on the tranny-where the line installs?? so, this way i can put dummy plugs in, so i do not lose alot of fluid!
Old Apr 24, 2007 | 07:54 PM
megafast's Avatar
I would have to go look at mine, but I doubt you could plug the lines. I bet they used a ferreled fitting.
Sorry, I just reread your post and you are wanting to remove the whole line. Not sure what size those are.
Old Apr 24, 2007 | 09:02 PM
rjm022's Avatar
i think i may have the old line around somewhere. but if somebody knows- i would appreciate it!
Old Apr 24, 2007 | 10:33 PM
RamWheelsBy4's Avatar
Well when mine was installed i don't think a pint of fluid came out if that.
Old Apr 25, 2007 | 05:10 AM
rjm022's Avatar
that is what i read from other posts before i did the install. but when i did it- i lost close to a quart of fluid!! i was surprised!-after reading several posts of how there is hardly any fluid loss! not in my case!
Old Apr 25, 2007 | 05:20 AM
dangier's Avatar
rjm022
Just did mine last weekend. I had the truck tipped to the passenger side some and only lost a few ounces. Did not leave it open long though. The fittings are hydraulic type and both are different sizes. My old piece is two hours away so I can not give you the sizes right now. Your best bet if you need to leave it off for a period of time is to put the original back in. Good luck.
David
Old Apr 25, 2007 | 09:48 AM
Well go figure , mine was on a lift off the ground and basically level. It had been sitting for at least an hour maybe more to cool off, maybe that drained more fluid back into the pan.
Old Apr 25, 2007 | 04:58 PM
rjm022's Avatar
bought some plugs today at home depot. i was able to find the old line. good trick-i'll slightly jack the truck-so i can slow down the fluid loss.
Old Apr 25, 2007 | 09:23 PM
The more I think about it mine was sitting for probably 2 hours at least had to go to Home Depot the get an adapter to put the sensor in.
Old Apr 26, 2007 | 05:11 AM
rjm022's Avatar
i remember when i first put th line on- the majority of my fluid loss came within the first couple of minutes-then it just became a dribble. total fluid loss when done-was 3/4 of a quart.
Jona Gold
29
Jan 19, 2025 06:36 PM
Pearce
May 22, 2008 08:19 AM
bansheetroy
15
Dec 20, 2007 05:29 PM
RonP
Nov 12, 2004 07:17 AM
CTD2001
Apr 24, 2004 08:55 AM
