Manifold for Twins
Old Dec 4, 2008 | 03:48 PM
Hintz's Avatar
Manifold for Twins
Im going w/ twins on my 06, is there any advantage using an aftermarket manifold vs a 24v stocker besides flow?
Old Dec 4, 2008 | 03:49 PM
soulezoo's Avatar
DTR 1st Sergeant
The three piece design ATS uses eliminates cracking problems from heat expansion.
Old Dec 4, 2008 | 04:07 PM
homewrecker's Avatar
The cracking problem is not very common.It does happen but not very often.I have buddies with bombed 24V's that still run the stocker and have had no failure issues.If money is an issue then I would run a stocker,if its not go ahead and get the 3 piece.I have 2 24V's that are moderately bombed and they weigh in at 18K lbs gross combined weight everyday.The egts are always on the upper edges of safe and still on the stock manifolds with over 170K miles on both trucks.
Old Dec 4, 2008 | 04:51 PM
kantdrive55's Avatar
DTR Advertiser
3rd Generation Dodge trucks with the 600 series motor (2004.5+) and newer have a single opening or single volute exhaust manifold/ turbo combination. This design does not utilize the engines individual cylinder pulsing action to drive the turbo faster from slower speeds. When a customer upgrades their OE turbo to an aftermarket turbo it is highly recommended that they upgrade to a pulse manifold as well. As this will ensure the pulse action is not wasted and will spool the turbo faster.
dodgediesel
ABDTR #5
Oct 18, 2011 09:22 PM
dodgediesel
ABDTR #5
496
Oct 16, 2011 04:33 PM
dodgediesel
17
Apr 5, 2011 11:21 AM
Stock 02
28
Sep 24, 2006 11:09 AM
Dusty Ratcliff
Apr 2, 2006 11:08 PM
