made a post on diablo site wanted to ask here as well. For the predator.
Old Jun 28, 2007 | 11:07 AM
Mark03Ram's Avatar
Looking for something that breaks down the real time data parameters. What does each section contain and what does each parameter stand for?? The basics are obvious, rpm, coolant temp, fan, ect. What about the other abbreviated parameters.
Maybe a description and multipliers if needed so they make sense. Trying to figure out a lack of power issue with my truck and figured I might be able to log more indepth info to find the issue.
BTW its a 03 3500 with the 305/555 U7130 predator on the non stacked performance tune. No puck installed at this time.
Figured all the traffic here someone might know where to look, thanks guys.
Old Jun 28, 2007 | 11:30 AM
trik396's Avatar
I pretty much had to figure out what they were myself and I'm still not sure of the majority of them. HPCRpress is rail pressure in Mpa which to get to psi you multiply by 144 or 145...
Your lack of power problem... have you checked/changed fuel filter and air filter. Sometimes it's the simple things...
Old Jun 28, 2007 | 11:58 AM
Mark03Ram's Avatar
All new filters, thinking it might be the lift pump so wanted to see if the rail was dropping preassure.
Old Jun 28, 2007 | 12:11 PM
trik396's Avatar
I think you need a fuel pressure guage. I'd pull my pressure down to zero with just Quad's XZT box before I installed my walbro pump...
Old Jun 29, 2007 | 10:34 AM
duallydave's Avatar
with the predator on rkl i drained my rail too,i thought i was the wastgate opening hard or somthing,i have the liftpump moved to the tank{factory waranty}but i need somthing more,ithink ill try some larger fuel lines first.
mx684
Apr 7, 2008 03:53 PM
PanteraGSTK
Oct 25, 2006 02:24 PM
Mark Craig
103
Jun 2, 2006 02:24 PM
kelley15
May 18, 2006 09:21 PM
AKDSLDOG
Nov 7, 2003 07:55 PM
