Diablo Predator 2003-05 Programmers are OUT!!
Morning,
Just wanted to let the membership know that the Diablo Predator programmers for the 2003-05 Dodges is finally available. Our first order got here yesterday and they have even included a pre paid comment form for the first batch of them to get feedback from users!
Features are:
2003-04 60HP and 100HP and 160HP levels
2004.5-05 60HP and 90HP and 120HP levels
Internet upgradeable and they will have custom tunes available at the 200 HP level.
Here are the diagnostic items that are readable:
"Engine Speed"
Transmission oil temperature"
Vehicle speed",
Throttle position",
Throttle position before idle validation"
Transmission oil temperature sensor"
Transmission governor pressure"
Engine coolant temperature"
Engine coolant temperature sensor"
Boost pressure"
Intake air temperature"
Intake air temperature sensor"
Battery Voltage
Transmission output shaft speed"
Water in fuel"
Transmission VFS PWM duty cycle"
Final fueling"
4D fueling table output"
AFC fueling table output"
LSG fueling output"
ASG fueling output"
HSG fueling output"
Target governor pressure"
Pedal Position Sensor 1"
Pedal Position Sensor 1 voltage"
4D timing table output"
AFC timing increment"
Misfire minimum timing"
Pedal Position Sensor 2"
Pedal Position Sensor 2 voltage"
Wastegate duty cycle"
MAP sensor"
Water in fuel sensor"
Percent Load"
The calibrated maximum fueling that the system may output"
The calibrated maximum engine speed for 100 percent throttle"
The calibrated maximum engine speed for zero percent throttle"
Intake Air Heater Control Status"
Initial ambient air pressure"
Misfire Total Attempts Number"
IAH Temperature Input0"
CTIR Delta Temperature"
Battery Temperature"
Engine Speed from Crankshaft ESS"
Engine Speed from Cam Gear EPSI
TPS Voltage (only reported in TPS applications)"
cruise cannot be entered"
cruise was disengaged"
cruise is engaged"
cruise light requested"
cruise switch status"
Cruise Control Reference Speed"
Cruise Control Switch Mux Raw
Torque Control Indication"
Coolant Temperature In Range Monitor State"
Total Fuel Used"
Trip Fuel Used"
Total Time"
Trip Time"
Total Idle Fuel Used"
Trip Idle Fuel Used"
Total Idle Time"
Trip Idle Time"
Total Distance"
Trip Total Distance"
Trip Average Fuel Economy"
ECM Run Time"
Engine Run Time"
Average Engine Speed"
Battery Voltage Raw"
HPCR Fuel Pressure"
HPCR Fuelpr Setpoint"
Fan Speed"
Fan Clutch 1 PWM Duty Cycle"
DC Mon Percent Time Under Load 0-10%"
DC Mon Percent Time Under Load 11-20%"
DC Mon Percent Time Under Load 21-30%"
DC Mon Percent Time Under Load 31-40%"
DC Mon Percent Time Under Load 41-50%"
DC Mon Percent Time Under Load 51-60%"
DC Mon Percent Time Under Load 61-70%"
DC Mon Percent Time Under Load 71-80%"
DC Mon Percent Time Under Load 81-90%"
DC Mon Percent Time Under Load 91-100%"
Vehicle Configuration and Learn Mode Status #1"
DC Mon Percent Time Under Load motoring"
DC Mon Percent Time Under Load high idle
VTA SKIM Status"
VTA SKIM Status"
Ambient Air Pressure"
Ambient Air Pressure sensor"
Ambient Air Temperature"
Ambient Air Temperature sensor"
Cylinder Contribution 1"
Cylinder Contribution 2 (percent contribution from physical cylinder 5)"
Cylinder Contribution 3 (percent contribution from physical cylinder 3)"
Cylinder Contribution 4 (percent contribution from physical cylinder 6)"
Cylinder Contribution 5 (percent contribution from physical cylinder 2)"
Cylinder Contribution 6 (percent contribution from physical cylinder 4)"
Cylinder Bank Contribution 1 (percent contribution from physical cylinders 1-3)"
Cylinder Bank Contribution 2 (percent contribution from physical cylinders 4-6)"
Cylinder Performance Test
HPSV Test Active"
Other features to be listed as the information comes out.
Of course we are having a special "new item" sale on them so call us if you are interested in it etc.
Mark @ DPPI
Features are:
"Engine Speed"
Vehicle speed",
Throttle position",
Boost pressure"
Battery Voltage
Water in fuel"
Final fueling"
LSG fueling output"
ASG fueling output"
HSG fueling output"
MAP sensor"
Percent Load"
cruise is engaged"
Total Fuel Used"
Trip Fuel Used"
Total Time"
Trip Time"
Total Idle Time"
Trip Idle Time"
Total Distance"
ECM Run Time"
Engine Run Time"
HPCR Fuel Pressure"
Fan Speed"
VTA SKIM Status"
VTA SKIM Status"
HPSV Test Active"
Mark @ DPPI
Mark, Is that all it can do?
Sounds great!!! and Now for the famous question. Is it compatible with duration and timing boxes, duration, or the others. Any recommendations on not using with other boxes. ks
How in the #%$$ do they get that much stuff into a little box
!!!! That is pretty impressive, and I wish that they had come out sooner, like when I had my 03 SO!!I would really like to have someone try it and give the details!!
Originally Posted by abc4yew
A 200hp tune just like the 230hp cldl tune....that would be the 160hp their advertising. I know of no one who put on a cldl and got 230hp without a squirt. ks
crazy larry 4 dodge is only 180hp, the 230hp is 4 dmax
The manufacturer: Programa Tools
Mark, I didn’t see anything on your web site about it yet. Am I missing it or is the info still pending? PDQ doesn’t even have anything out about it yet. I'm curious whether it addresses things like Torque Management, RPM limiter, speed limiter, etc….you know, the really cool stuff.
Brian
Brian
thejoker502,
The site allows Sponsors to make one monthly post about a sale or new products. That's what I did the other day to let the membership know about the new Predator by Diablo. If you want one we have a introductory price on them and have a limited supply. Each one of these has a pre paid response letter that Diablo wants back to see what customers think about them. The site rules don't like us posting prices so you'll have to call us at 866-455-7788 and we'll tell you etc. As I get more info I will post it.
Mark @ DPPI
Mark @ DPPI
I just ordered mine and I will be smokin in a couple of day's. I had a diablo sport for a 03 ford with a 6.0 and it worked great. Too bad the 6.0 would'nt stay running due to all the wiring and injector problems, but that is why I am driving a Dodge now and loving it.
