Low boost?
Low boost?
I just instaled gauges, and my boost is running about 0 at idle and have had it up to about 10 to 15 psi at about 60 mph, is this a bad gauge? oh yea and I have it routed to the ATS arc , everything else seems to be fine.
Get on the go pedal on a freeway on ramp....boost is at it's highest during acceleration...not at steady throttle / cruise....stock is around 30-32psi
I am not seeing anywhere close to 30 or 34psi , but I have found no leaks,and the gauge was tested ,it works, would this be something to try a boost fooler on? Will the bully triple dog give the electic wastegate problems?
Notstrokin,
For a while I was having an issue with low boost. What I found out is that I had to re-adjust the front bands on the trans. That brough everything back to snuff. In fact it made it feel like I put a VB in.
As for boost, I guess I'm seeing allot less than everyone else. I can't seem to find a leak, but I thinking that becuase I have a TAG my boost levels are lower. With the Quad Std by-passed, cruzin' at 60mph I'll read between 0-3psi, a long grade at 70mph I'll get to 17-20psi, full accelleration she'll peg 36psi & settle around 32psi. I think everythings fine because I can max it out to where it should be.
What do you guys think?
I thank you all for your input, any of it does help,for I am fairly new to these rigs but man they sure are cool and they are addicting LOL. All of my buddys drive powerstrokes,and none know anything compared to what I learn here.
Moobesor
Feb 23, 2008 09:57 AM
