Losing coolant!!!
Old Sep 8, 2008 | 09:38 PM
  #31
georgboy's Avatar
Originally Posted by StealthDiesel
As someone mentioned already, have you checked below your coolant overflow tank?
This is common on the 04.5 and newer trucks and is where my coolant was going.
I did this slick little mod and problem solved...
http://wiki.dieseltruckresource.com/...olant_Drip_Fix
...Joe
Oh tell me more because I am stumped I tried the link didnt pull up. thanks a million man. I am starting to worry its getting worse.
Old Sep 8, 2008 | 09:46 PM
  #32
Spooler's Avatar
Do the oil analysis. If you have a leak it could be one of the freeze plugs in the head under the valve cover/rocker box. Otherwise you will find a peepee trail of pink/white chaulky antifreeze somewhere as long as you still have the factory antifreeze in it.
Old Sep 8, 2008 | 10:25 PM
  #33
StealthDiesel's Avatar
Hmmm, that link works for me..
From the top of the page menu list, choose "Articles".
Then from the top left menu's choose "Diesel Technical Articles".
Then under 3rd Gen, choose "$2 Dollars - 15 Minutes - And No More Dripping Coolant ---> "
...Joe
Old Sep 10, 2008 | 06:39 PM
  #34
georgboy's Avatar
Found the leak!!!!! I think it is the water pump it is coming from the front right side of the engine. I have been looking at it each day after driving home and did not see anything. Today I just went all out and turned her on up got to about 102 and got to the house looked under her and saw a small drip on the bottom of the right side. I know I shold not have done this lol but tasted it and it was coolant. Can someone tell me how much a water pump cost and how much to install? This is the only problem I have had with the truck since I bought it new. Thanks again guys for all the help figuring this one out.
Old Sep 10, 2008 | 08:05 PM
  #35
Spooler's Avatar
Get one at NAPA for about 80 bucks. Coming out the weep hole, that's normal.
Old Sep 10, 2008 | 09:39 PM
  #36
georgboy's Avatar
Is that the best one? I dont want to do this again in 80,ooo lol.
Old Sep 10, 2008 | 09:43 PM
  #37
homewrecker's Avatar
Can always get one from Cummins,not sure on the price.Its an easy part to change,be glad its not a 7.3 psd your dealing with!
Old Sep 10, 2008 | 09:48 PM
  #38
georgboy's Avatar
Yeah I am sure its going to be fun taking the fan and shroud and all that other stuff off lol
Old Sep 10, 2008 | 10:16 PM
  #39
Just drain the cooling system,remove the drive belt and take the 2 bolts off the pump and its out.It uses an o-ring seal so no gaskets to mess with.Vey easy job.No need to mess with the fan and shroud.
Old Sep 10, 2008 | 10:54 PM
  #40
georgboy's Avatar
Oh its that easy?Where is the drain on the radiator at?
Old Mar 10, 2020 | 08:50 PM
  #41
Todd Arp's Avatar
I have 2018 Dodge 6.7 3500 Ram dually with 170,000 miles. I am losing coolant from somewhere. There is no obvious leaks or smells and the motor is running fine. There is no coolant in the oil. I have looked all over the engine and no visible leaks. I have had it into to different shops who have done pressure test on coolant system and found no leaks. The second shop though maybe the EGR is leaking coolant into the exhaust when pulling a load on causing the the low coolant sensor light to come on. Has anyone else had this problem? Thanks for the help guys.
Old Mar 12, 2020 | 12:18 AM
  #42
sojoe's Avatar
Looked today after driving for 20 miles no signs of any leaks. Although I have noticed the res. level has dropped over an inch in two days where the heck is it going. Still no smell of burnt coolant either. I dont know what to do lol.
Have you checked the clamps/hoses when COLD.
Often times a cold water leak will go away when the system warms up.
Old Mar 15, 2020 | 04:47 AM
  #43
tryNto's Avatar
Hey, you might find someone who knows more about 4 gen trucks in the 4th gen section. https://www.dieseltruckresource.com/...n-2010-up-201/
Kach
May 5, 2014 04:14 PM
jerry007
Apr 7, 2012 08:34 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
NO_SPRK
Jan 6, 2009 04:27 PM
popeyesides
Dec 6, 2004 03:43 PM
