Losing coolant!!!
Old Sep 4, 2008 | 08:11 PM
georgboy's Avatar
Gone to take a look at this hose
Old Sep 4, 2008 | 08:23 PM
georgboy's Avatar
looked everywhere no leak. This makes me wonder
Old Sep 4, 2008 | 08:25 PM
georgboy's Avatar
Originally Posted by Mocho
I have the same problem I think, never really looked at coolant level until a few weeks ago, was pretty close to add line. But one thing I noticed, the coolant level changed a good 1" from when the truck was sitting for a few days compared to a few hours. No noticable leaks here either, waiting on a oil analysis.
What did your oil tell ?
Old Sep 4, 2008 | 08:35 PM
pos dodge's Avatar
Pressure
You could always pressure test the coolant system. Usually any leaks will show up immediately.
Old Sep 4, 2008 | 08:46 PM
Mocho's Avatar
Still waiting to get it back actually, tomorrow it will be 2 weeks....I'm guessing it's just me but since I noticed it I swear my truck runs a bit rough at idle, but like I said i'm positive it's just me. The truck still has tons of power though, pulled 13k trailer last week with zero issues....
Old Sep 4, 2008 | 10:57 PM
georgboy's Avatar
Garmon said
I talked to Jeff Garmon and he said I should pressure test it.The only thing is he said if the head gasket is blown that when I pressure test it,and if it is blown there will be water on top of the piston and then a tow truck to the shop. 1200 for a stock head gasket replacment. 2400 to 2800 for studs, o rings,and new head gasket. He also said that he finds it hard to believe that with a stock turbo that I have blown a head gasket. He also said that the third gen. trucks have a strong head gasket in stock form.
Old Sep 5, 2008 | 08:15 PM
georgboy's Avatar
Anyone have any suggestions or tricks to find coolant leaks?
Old Sep 6, 2008 | 02:22 AM
DaveB.inVa's Avatar
Its been mentioned... but take a good look at the overflow tank. The opening on it is huge and any sloshing will run a good amount of coolant out.
I've dumped coolant in my girlfriends driveway a few times when I've pulled in. Her driveway points downhill and if I stop too quickly it will slosh and run out.
Old Sep 7, 2008 | 02:16 PM
georgboy's Avatar
How tight should the heater hose on top of the block be? It was loose enough to easily turn it with a wrench last night.
Old Sep 7, 2008 | 10:38 PM
georgboy's Avatar
Spooler where you at man?
Old Sep 7, 2008 | 10:42 PM
georgboy's Avatar
What kind of atf 4 to run in g56 6 spd?
I was wondering what brand of atf type 4 trans fluid you are running? Thanks guys
Old Sep 8, 2008 | 08:01 PM
georgboy's Avatar
Looked today after driving for 20 miles no signs of any leaks. Although I have noticed the res. level has dropped over an inch in two days where the heck is it going. Still no smell of burnt coolant either. I dont know what to do lol.
Old Sep 8, 2008 | 08:07 PM
Spooler's Avatar
Pull an oil sample, that will tell you about coolant in the oil. How high in the coolant overflow is the coolant? Is it still in the safe zone? If you fill it too high I have heard of it going missing from the resevior for with no leaks detectable. You may be worrying about nothing.
Old Sep 8, 2008 | 08:24 PM
georgboy's Avatar
The oil is still at the full line and the exhaust doesnt smell like antifreeze.
Old Sep 8, 2008 | 08:47 PM
StealthDiesel's Avatar
As someone mentioned already, have you checked below your coolant overflow tank?
This is common on the 04.5 and newer trucks and is where my coolant was going.
I did this slick little mod and problem solved...
http://wiki.dieseltruckresource.com/...olant_Drip_Fix
...Joe
