Looking for some thoughts..
Old Jul 7, 2006 | 07:06 PM
Keyser Soze's Avatar
Ok this might be a dumb thought or not..
I use to run my twin turbo mustang, twin 62mm... on the street all day long and in traffic and this is South Texas we all know its hot here.. Anyways.. I use to run and air-to-air intercooler, like our Dodges..
The i upgraded to an air-to-water intercooler and i had a 5 gallon water box that was insolated that i filled with ice and water and man alive, i could spin the tires at a 70mph roll, i mean it became a beast when i had ice in there.. It was a b**** to hook up..
The air-to-air didnt run any hotter then the air-to-water..
I mean could this be done to a diesel intercooler??
I mean it could be the stupidest thing i have ever thought up..
Then again, forgetting to put a jet in a NOS line was pretty stupid, yep i sprayed ALOT of NOS in that car, and it went B-O-O-M!!!!!!!!!
I'm just lookin for your guys opinion on this..
Old Jul 7, 2006 | 07:27 PM
stang's Avatar
air to water is the best for drag racing but when you burn off all the ice the water gets hot your done diesel goes boom air to air for street and drag racing air to water for drag racing only now here is hot ticket good air to air and water/meth for racing and you can spank that a$$ now you have the a$$ kicking for when you are street racing check out www.snowperformance.net and he did all his testing on a Dodge. Matt drive's it every day hope this helps you out
Old Jul 7, 2006 | 07:47 PM
yeah, i kinda figured it wouldnt be a great idea, but i was just getting a few peoples thoughts on it..
i imagine a diesel gets way hotter then my stang ever did..
Old Jul 7, 2006 | 07:57 PM
stang's Avatar
depends on how much boost you were running in the stang I know it was not to much or you would of been changing head gaskets all the time. and it depends on were you were on the map of the turbos or if they were surging or not might of made more heat but after you change the head gaskets afew times you start to figure it out pertty quick
Old Jul 7, 2006 | 08:20 PM
i was running 18lbs.. I had the pistons coated so they could handle more heat and i had the heads lock wired, i use to blow gaskets before that like there was no tomorrow haha..
Old Jul 8, 2006 | 01:15 AM
Erik's Avatar
Another intercooler..electric.
There is also a electric intercooler that is being developed here in Albuquerque. The owner has just presented it to Ford and sells a kit for ..I think was about $1100.00. It dropped the temp about 180 degrees. If you want I can call Joe (the owner) and get his business number for more info if you want.
Erik
Old Jul 8, 2006 | 02:49 AM
Michael1's Avatar
Erik
What's an electric intercooler?
Old Jul 8, 2006 | 05:21 AM
Erik's Avatar
Thermoelectric cooler..
The same principal as the little coolers that you plug into your electric socket to cool your sodo pop without ice. Reverse the system and it heats. Was invented about 100 years ago.
Erik
Old Jul 9, 2006 | 07:02 PM
Erik's Avatar
Electric intercooler contact #
If anybody wants to contact the owner and designer of the electric intercooler, I can get the number from Joe (the guy ) and you can talk to him personnally.
Erik
idlewildranch
Jul 28, 2010 10:29 PM
tnchris
14
Mar 11, 2006 06:58 AM
nord
Sep 11, 2005 12:11 AM
PapaPerk
23
Jan 1, 2005 07:33 AM
Ram44maR
Sep 19, 2004 06:55 PM
