Looking to by 17x9 or 10 wheels need help with tire sizes
Old Feb 27, 2006 | 06:31 PM
SmokinDodge12V's Avatar
Im going to get some aftermarket wheels and need help on what size tires to get. My stock size is 245/60 or 65R17 I would like to stay the same height but much wider but dont know what Im looking at when it comes to all the different numbers. Thanks
Old Feb 27, 2006 | 06:54 PM
TopBanana's Avatar
metric tires confuse a lot of people. hopefully this will help,
for example your tire size, 245/65/17
245 refers to the width of the tire, it's 245 mm wide.
65 is an aspect ratio of the width and side wall. meaning, the side wall of the tire is 65% of the 245 mm width. or roughly 160 mm.
17 refers to the rim size.
so a 245/65/17 is about 9.5-10 inches wide and a tad under 30 inches tall.
here's a link that allows u to use a conversion computer is find alternative tire sizes. scroll all the way down the page.
http://www.bncoffroad.com/ratio/
Old Feb 27, 2006 | 07:07 PM
Thanks that helps a little. So a 305/50R17 would be about the same height but a lot wider.
Old Feb 27, 2006 | 07:17 PM
TopBanana's Avatar
yep, that's correct.
although i'm not sure if anyone makes a tire in that size. check toyo, and nitto's websites they usually make a lot of different sizes
Old Feb 27, 2006 | 08:09 PM
How wide would a 285/60R17 be?
Old Feb 27, 2006 | 08:18 PM
G1625S's Avatar
285mm wide, or 11.22 inches
Old Feb 28, 2006 | 08:30 AM
tcr's Avatar
tcr
Stay w/ 17x9s, the 17x10s will cause even a 33" tire to rub. I now have 33/12.50/20s and they rub the rear of the front fender pretty good, plus I have a 2" level kit.
Old Feb 28, 2006 | 12:09 PM
I will not be running a tire that tall it is for my 2wd and I also do not want the back spacing to be the same as stock I would like them to stick out a little.
Old Feb 28, 2006 | 12:17 PM
MikeyB's Avatar
Check with member 'badram'. His 2wd has 305's mounted on Pro Comp wheels. But he also has a Daystar 1.5" lift.
MikeyB
Old Mar 1, 2006 | 08:34 PM
Does nobody make an LT 30 10.50-11R17 tire other than a mud tire I can not find any tires to go with 17x9 wheels Im going insane looking for tires.
redneck_ram
3rd Gen All Products
0
Feb 11, 2015 05:36 PM
Mopar72
Jun 18, 2007 06:04 PM
UnrulyNFS
Jan 29, 2007 08:01 PM
ataboy9026
Dec 11, 2005 10:29 PM
