Lift needed?
Old Jul 9, 2005 | 03:20 PM
Kids Toy's Avatar
Cool Lift needed?
I`m interested in running 35 in .mudders and was just wondering if a guy needs to do a lift to the truck or just a leveling kit to it.I understand that they do rub slightly.I like the look the 35(315`s)give the truck but If they rub then I go with 33`s(305).Any info is good info.....
Old Jul 9, 2005 | 03:53 PM
4x4not's Avatar
35s will fit without a lift, but depending on the backspacing of the wheels they may rub a little bit at full lock. I have 315/70R17s (35") on factory chrome steelies and mine rub a tiny bit.
Old Jul 9, 2005 | 03:54 PM
Jmac's Avatar
Mine rubbed on the wheel well. I'm putting on a 4.5" tuff country lift tomorow as long as the Hurricane passes on buy us.
Jamie
Old Jul 9, 2005 | 04:13 PM
Kids Toy's Avatar
I`m running the stock aluminum rims.
Old Jul 9, 2005 | 04:18 PM
Kids Toy's Avatar
And I`d like to gain some xtra clearance under the truck ,to keep from scraping the underside and running boards.So I was hoping for 35 but some tire store people so no,they don`t fit.
Old Jul 10, 2005 | 05:10 PM
bama's Avatar
mine doesnt rub at all,but,,they also dont have but maybe an inch clearance at most at the wells..im also running h2 wheels ,so maybe they make a little difference.they dont rub the control arms at full lock at all............bama
Old Jul 10, 2005 | 10:45 PM
BigBlueDodge's Avatar
I have stock chromed steel wheels with BFG 315's and mine rub at full lock. Many people have put on 2' leveling kits and removed the rub. If you are going to aftermarket wheels, then becarefull of the backspacing. Note that for most 35" tires, the stock 8" wheel does NOT meet the manufacturers minimum width so keep that in consideration as well.
Old Jul 10, 2005 | 11:06 PM
Kids Toy's Avatar
Thanks ,I`ll keep all this into consideration when looking for rubber
Old Jul 10, 2005 | 11:10 PM
NHdodgeman's Avatar
You can crank the torsion bars up. Turn them 5 times and its about two inches of lift on the front end. Make sure to have an alignment shop do it as you will change the geometry of the front end.
Old Jul 10, 2005 | 11:16 PM
Torsion bars are only on the 1/2 ton trucks. The heavy duty trucks don't have torsion bars
Old Jul 10, 2005 | 11:25 PM
Jmac's Avatar
Besides I did that with my 03 4x4 4.7L and it made the ride very stiff on the front end. Basically it @#$!'d.
Jamie
Old Jul 11, 2005 | 02:10 PM
4x4not's Avatar
Have you ever looked under your truck?
Old Jul 11, 2005 | 04:31 PM
RamWheelsBy4's Avatar
I have 2" leveling kit and 315s(34.4") on stock rims. I do not have any rubbing. It looks to me that aftermarket rims with less that 5" or so back spacing would probably rub on full lock. True 35" tires probably would for sure.
Old Aug 17, 2005 | 12:01 AM
Kids Toy's Avatar
Thanks for the infoRamWheelsBy4.I`ll have to look into prices for a leveling kit.Sorry that It`s taken so long to respond but I`ve just been stuck out in the bush since the 10 of July.
STR8TORQUE
Jun 6, 2007 10:03 AM
DennisT
May 30, 2007 10:42 AM
DennisT
May 15, 2007 01:29 AM
35xj
Jan 11, 2006 08:32 PM
texgunner
Nov 22, 2005 01:13 PM
