Just What Can I do before Voiding My Warranty
OK I love my new 06' 3500 Mega Cab 4x4, And I plan on buying a Quadzilla Commander to monitor things. But just how far can I go before I void the warranty.
I would highly recommend stopping into your service department & getting to know the service manager. Get his thoughts on your question & maybe see what he would recommend you doing. If nothing else, it builds a relationship between the two of you & he will appreciate your courtesy of checking in with him first.
Yep, the DC big brother is listening and any thought or discussion of modifications will void engine and drive train warranty. You should still be able to get the door seals replaced and maybe the TSB for the Not In Park
horn honking.
horn honking.
horn honking.
horn honking.
And about putting in your own fuel, sure as heck dont wait for the dealer to do it! You've spent almost (or more) 40 grand on a vehicle, they dont have to top it off for you!
Yea, sorry to say your thread took a turn for the giggles pretty quick.
Well in a more serious vane, it does really depend on the service department on what will slide without problems. Cat back exhaust or straight pipe is pretty safe, air intake probably ok. Gauges should be, but then again drilling into the exhaust manifold may cause questions. You really should just talk to your service manager and get his opinion.
But the bottom line is if you have major engine or drive train problems, DC Star will most likely get involved and then any mods could give them excuse to void warranty. Just my .02.
Just a note and I do not have first hand experience (yet)... I noticed in the notes on the jake brake that my 06 3500 came with (dealer installed and warrantied), there is apparently a bung already there for an EGT probe.
There are laws that allow you to replace O-E-M parts with comparable quality aftermarket parts but adding anything other what the vehicle was "designed for" is not protected by law. For instance a factory tie rod end is replaced with a TRW tie rod end that meets or exceeds the design specifications and your power steering pump fails a week later the dealer cannot void your warranty because of the tie rod end replacement. However if you add an electronic performance enhancement box, good luck getting warranty work done on the engine. There are lots of gray areas between these two extremes.
Just because your local dealer says that is acceptable another dealer that you may require warranty work from if you're out of town on vacation may say so sorry.
L8r,.............dogger
Ah Hell that's all rite I can take some new guy smack
This really suck's. I new it was going to be bad but not this bad. I'm really wanting a Quadzilla Commander for monitoring things at least, and if I have to go from Cat back for now on the exhaust, well thats what I gota do.
I just can't start dropping sh$t in this thing rite now and void the warranty on a $37K truck I waited 3 years for, well I guess I could, and I'm sure guys do, but I can't bring myself to do it "Yet".
I'll hang for awhile and see how long I can hold out. I havn't even got to the first oil change yet.
.This really suck's. I new it was going to be bad but not this bad. I'm really wanting a Quadzilla Commander for monitoring things at least, and if I have to go from Cat back for now on the exhaust, well thats what I gota do.
You don't even really need a cat back system on the 06 truck. All you really need is a performance muffler replacement. Oh and a cool 5" or 6" tip!
Like everyone else says, your particular dealer is the key as to what you can get away with or not.
Most of us make products than can be easily removed for service but, anytime you do anything you stand a chance of the dealer getting irritated. Even if the box leaves no fingerprints and you were to accidentally monkey a wire up or something they might throw a fit?
We have a lot of people that run our modules and remove them without any grief. On the other hand if they have any clue they might hang you?
gsegelk
Nov 30, 2006 01:07 AM
User Name:
17
Nov 1, 2006 08:46 AM
pet05
Aug 19, 2006 05:53 AM
koogala
14
Apr 10, 2006 09:48 PM
