Just installed Quad Adrenaline...
Got the Adrenaline and Pulse installed last night. So far I'm pretty impressed, but I already figured out I'm going to need a turbo if I turn it up much
. Get's hot quick on 13. Running on level 7 it does alright. Going to start at level 1, the mileage setting, and go from there to find out where it gets the best mileage.
Can't get the search to work, so I've got a couple questions:
Lift pump pressure sits at 8 at idle. Drops to 2-3 psi when accelerating. Is this something I need to worry about? I just switched from a second gen., so I've gotten used to worrying about lift pumps.
Rail pressure is at 7,400psi or so at idle. Hits 28-29,000psi WOT. Are those numbers ok? Haven't got a 2mic filter put on yet, and I'm kind of worried about messing up the injectors.
Any input is appreciated. Thanks.
. Get's hot quick on 13. Running on level 7 it does alright. Going to start at level 1, the mileage setting, and go from there to find out where it gets the best mileage.Can't get the search to work, so I've got a couple questions:
That LP pressure is normal with a stock pump...
Those RP numbers are high.
I run about 5500 @ idle, 11-13000 @ cruise and 20-21000 @ WOT...
I have mine turned down on the RP settings..
You want to stay under 23-24000 or so on the RP or you will be blowing the pressure relief valve. The high pressure wears the tip quickly...
I run my ADR on 3-4 most of the time...
The '03-04 run slightly lower rail pressure. I see in my '05 6500psi at idle, about 14-17,000 cruzin' (all +/-500psi). When you're not racing you're going to want to stay under 20,000psi rail pressure.
Lift pump pressure is fine for the time being. But you're going to want to get a different lift pump in the future. Personally getting down to 2-3psi is too low for me. I like to see minumally 10psi from the lift pump at all times.
You're going to want to minimally install a 2um fuel filter to keep the injectors lasting longer. Especially with running higher rail pressure.
I'm pretty sure your rp reading is wrong. The sensor can only read up 26500psi. The only way to read pass that is get a 6.7 sensor which I hear can read just north of 30000 psi.
Lp pressure like stated above is good.
Keep everyone posted on how it works!
So far I'm liking it. Haven't had time to play with it much yet, trying to get a backhoe running...
vzdude
Oct 17, 2007 04:32 PM
RedRacer44
May 3, 2007 10:37 AM
jlarmour
15
Mar 29, 2007 07:37 PM
DWG05
Nov 26, 2006 12:29 PM
xblshortcut
Dec 15, 2005 07:41 PM
