Just got an external wastegate
Just got an external wastegate........ not sure were the best spot on the manifold is to mount? I know its somewhere in the middle; should I drill stright down on top? or drill off to the side alittle cause the flange is in the middle?
Ya there is a thing called to much boost and to much drive pressure and
i have it.Im running a A5000 with a 1.0 houseing and spinning it to 70 psi
i think it out of its mapping and drive pressure through the roof. I got a
TAIL waste 44mm for $360 and i really nice boost controller for $60
also;
also;
i assume u have an aftermarket exhaust manifold, make sure when u weld it up u get someone who is good at welding on cast iron, the ones i have seen have the waste gate flange welded in the middle lower portion of the manifold
RowJ
Mar 1, 2005 04:50 PM
AK RAM
24
Jan 20, 2005 08:50 PM
KatDiesel
Mar 11, 2004 07:31 AM
