Juice help
Old Mar 30, 2006 | 08:58 AM
marc03's Avatar
Juice help
I installed my j/a last night and have some issues. First I got codes p0882 & p0237. Also my boost will hit 38 on 3 and 40+ on level 5. Also my trans slip function is not working the speedo part is working correctly,but it always says converter unlocked. Anyone have some of the same issues?
Old Mar 30, 2006 | 01:08 PM
Booger's Avatar
I had taken my Juice/Attitude out for a while and when I put it back in it threw a P2149 code, if I remember right, it is something about the injectors. The truck ran very rough at idle and didn't have power to move. I took it out and all is fine now. Called Edge and they said send it to them. Haven't heard back from them yet. As for the boost, I can hit 42lbs in all settings. 38-40 driving strong but not WOT. If I could find something to add power without fuel pressure or excessive boost I would switch. The boost scares the crap out of me. I also have mechanical guages so I now for sure the boost is right. I wander if you could unhook the data sensor or something to return boost to stock 30lbs? I don't know which plug unlocks the electronic wastegate. Any ideas?
Old Mar 30, 2006 | 01:30 PM
TRC51's Avatar
Doesn't the EZ do that?
Old Mar 30, 2006 | 02:49 PM
Booger's Avatar
I thought the EZ did pressure only. Which cause fuel pump problems. If I am wrong please tell me so. Maybe the EZ would be for me.
Old Mar 30, 2006 | 04:58 PM
RamWheelsBy4's Avatar
If you have had your ECM "Pinion Factor" reprogrammed for your larger tires, then the transmission monitoring or defueling will not work. You should see a NOTE in the instructions somewhere that confirms that.
The boost numbers are normal or at least about the same that I saw with the standard Juice/Attitude.
Might check the MAP connections and make sure everything is connected fully.
Old Mar 31, 2006 | 07:27 AM
Originally Posted by Pull U 2
My pinion factor has been changed and my Attitude shows TC lock/unlock and the same slip I was reading before the pinion change.???????
Maybe they have fixed the reprogamming Pinion Factor issue. The lastest manual on their web site does not seem to have the same note/disclaimer anymore.
That was about the only issue I had with the Juice/Attitude.
Old Mar 31, 2006 | 09:05 AM
omaharam's Avatar
My boost never increased from stock after I installed mine. It never exceeds 36psi. I don't have exhaust yet (actually a MBRP muff and cat pipe arrived last week but haven't had time to install yet), will my boost jump 4-5psi by less exhaust restriction? I wasn't thinking it would, but has that been the experience of others?
5.0 Mustang Man
Oct 21, 2008 02:50 PM
SconsinSmoker
Feb 12, 2007 09:15 AM
bighornram
13
Nov 2, 2006 08:28 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
