Isspro EV2
Old Feb 25, 2009 | 02:41 PM
stroker101's Avatar
Isspro EV2
anyone out there have this installed in their truck to monitor "rail pressure"?
if so, how's the performance? installed mine today and it seems to be somewhat eratic. bad connection? IDK
it jumps up in pressure (milli-seconds) after the excellerator is applied and after the excell. is released, it will delay then, fall in pressure.
does a stepper motor work like this?
thanks for any education you throw my way
Old Feb 25, 2009 | 05:25 PM
coxy11's Avatar
ev2
Where did you hook the igntion,dimmer, & ground up to I just got my ev2 today wondering were the easiest place to hook up was.
Old Feb 25, 2009 | 06:11 PM
stroker101's Avatar
i just tied into the existing wiring from the other gauges that i have installed previously on my trk.
ignition-pink/yellow strip(large wire bundle located below parking brk
ground-aluminum frame above parking brk
dimmer-wire coming off of the dash dimmer switch
i believe that there was a diagram on here on "where to splice" for certain wiring goals. also try dieselmanor.com
Old Mar 13, 2009 | 02:52 PM
MichaelP's Avatar
The rail pressure tends to behave like that, the gauge is just responding to what the sensor is indicating. I assume it takes a little while for the pressure to bleed back down (at least it seems to take longer than it took to build it).
Regards,
Michael Pliska
hawaiianbro
Feb 10, 2011 07:52 PM
ZacMan5712
Dec 2, 2009 11:20 PM
ZacMan5712
Sep 30, 2009 04:14 PM
FBs555CTD
May 14, 2009 10:01 PM
garbri
May 13, 2009 11:18 AM
