isspro amp boxes
Old Aug 16, 2007 | 04:45 PM
rjm022's Avatar
isspro amp boxes
i have two isspro tranny temps gauges- hot and cold. over the past four months i have had several amp boxes replaced due to them being faulty!! finally, diesel manor had me deal directly with isspr tech dept. back at the beginning of july, isspro told me it would be august before they had any new amp boxes in- they are made overseas (go figure) and the compnay was on strike!! isspor tech dept called me yesterday to let me know their shipment of amp boxes came in!! he also went ahead and told me that out of the several hundered they recieved- only half of them tested good!!!!!!! just wanted to pass this info along- because i am sure i'll have more problems down the road-along with other members- so, we'll now know why these amp boxes keep going bad! probably made in china and only half of the amp boxes test good- so, i would imagine some slip through to the customers,etc!! not reassuring i say!
Old Aug 16, 2007 | 05:33 PM
ripping r's Avatar
I dont have a trans temp. but my pyro uses an ampbox. when i get it installed i hope i dont have these problems. do all the gauges use these boxes? or something diffrent.
Old Aug 16, 2007 | 08:45 PM
justin mcfall's Avatar
rjm, if the tranny probe is in the test port, it will not read accurately. i went thru the same thing with diesel manor. i finally put it in the pan itself and it has been working great for the past 3 months. hope this helps.
Old Aug 16, 2007 | 09:52 PM
rjm022's Avatar
i have one in the hot line i bought from diesel manor- the other probe is in the pan- the amp box in the hot line has been replaced twice- the amp box in the pan has been replaced once- i asked isspro if the amp box es could be tested to see why they are failing- they told me no!! they are throw aways!!
Old Oct 14, 2007 | 10:34 AM
Mud Ready's Avatar
Brought this thread back because I think Im having a similar problem. Finally hooked up the Isspro trans temp gauge I bought from diesel manor back in July and Im getting no reading. I flogged the truck for 30 minutes and the gauge never moved, the genos t-fitting that sensor is in is hot to the touch so I now the fluid was hot.
Did you just contact Isspro and send the old amp box to them and they sent you a new box?
Old Oct 14, 2007 | 07:06 PM
i e-mailed diesel manor, who contacted isspro who then sent me a whole new guage, amp box, and sending unit free of charge. i did not send the old one back....
Old Oct 14, 2007 | 08:03 PM
rjm022's Avatar
justin- that has happened to me twice.(whole new set up-free) diesel manor and isspro pretty much know me by first name- now.
Old Oct 14, 2007 | 08:13 PM
Mud Ready's Avatar
I sent an e-mail to Isspro and Diesel Manor. Its Sunday so Im not expecting a reply for another day or two.
Old Oct 14, 2007 | 09:47 PM
sorry about the spelling guys.gauge. i tested my new sending unit in hot water. i dont think the test port was getting enough fluid on the sending unit.
NoSparkplugs
Apr 25, 2008 10:54 AM
t-boe
Jan 4, 2007 08:35 AM
booman70
Sep 12, 2006 07:43 PM
Gear Poet
Apr 17, 2005 05:31 PM
drafalske
Jan 2, 2003 03:44 PM
