installing EGT
Thanks for the pic. Did you pull your manifold off? If not how do you keep the metal from going in to the turbo when drilling?
I have a prober where Fisherguy has his, and one after the turbo in the cast iron elbow. When drilling the manifold, start and idle your engine, it will blow out the shavings. Coat your tap in lots of grease in the flutes and clean often. Its not too bad to do, gets a little warm though.
Grease on the drill bit, starting with a small one working up to the final, then spun turbo with finger to make sure nothing's jammed, then fired it up with hole open to blow out crap, whole thing's spelled out in my gallery.
I installed mine right after the turbo in the cast elbow that connects the turbine to the downpipe. It works fine. You can go before the turbo just fine, but I HIGHLY recommend removing the exhaust mani before doing so. One little piece of metal in your compressor can have the potential to totally ruin your day.
As far as time consuming... well that is all on the perception and skill of the beholder.
RoadDiesel
Jun 29, 2007 11:52 PM
Gotlift01
Jul 29, 2005 09:44 AM
Lightman
50
Oct 24, 2004 04:02 PM
Thirsty600
Sep 7, 2004 10:54 PM
