Installing EGT gauge
I am about to install my gauges, and am wondering if I should remove my turbo before drilling the hole for the sensor?
I have heard that you can just run the truck while drilling, but I do not want to take any risks.
If I do remove the turbo will I need a new gasket for it?
Thanks, CJ
Thanks, CJ
I undid the four bolts holding the turbo to the manifold and moved it about 1-2 inches away and plugged it with a rag so no shavings could get in. I then drilled away without the engine running. When I was finished tapping, I cleaned it out with a magnet and a vacuum and then hooked it all back up. Worked great for me.
I am also trying to figure out how to drill the hole!!??
I am thinking the only way I can touch it is with a 90 degree drill?
Or could I just remove the wheel well linear? (I haven’t looked real close yet)
I guess if I had to, I could rent the drill.....
I followed instructions from a couple different sources.
Cover the exhaust tip with duct tape and leave about a 1/2" hole.
Keep lots of heavy grease on the tip of the drill. I kept cleaning the chips off and re-greasing.
Just before you start to break through, start the engine and complete the drilling. It whistles a bunch, it also splattered grease all over the hood, but no chips in the turbo
I also put mine right behind the shroud between 3-4, straight down. Seems to be a common place.
bansh-eman
Jan 4, 2010 01:01 PM
reedad
Jan 27, 2008 06:50 PM
jmccart
Mar 18, 2007 10:03 PM
Lightman
50
Oct 24, 2004 04:02 PM
I was planning to drill for the probe just above the turbo where the exhaust manifold is vertical, so taking off the turbo would be ideal in my opinion.
