which injectors (help)
Old Apr 7, 2006 | 11:09 PM
bigrittie's Avatar
I have an 03 3500 dually with cold air intake and TST box WHICH INJECTORS WORK BEST also tow 6000 lbs dailly PLEASE HELP??????
Old Apr 8, 2006 | 02:10 AM
TexasCTD's Avatar
http://www.f1diesel.com/contacts.html
I have never heard a negative thing about the Flux injectors by DonM. You can't go wrong with these. Here is his website contacts. His injectors recently helped Tomeygun push over 600hp with his 04 truck. Good luck.
Old Apr 8, 2006 | 07:16 PM
HP Upgrades's Avatar
You could look at the Edge Jammer nozzles, which are the injector tips only. There are three stages of nozzles that you install on your stock injectors.
* Stage 1 50 hp 100 ft. lbs. of torque.
* Stage 2 75 hp 150 ft. lbs. of torque.
* Stage 3 100 hp 200 ft. lbs. of torque.
We have them listed on our web site if you need to take a look at them to see what they are.
Old Apr 8, 2006 | 07:30 PM
Jeff K's Avatar
I like my Dynomite Diesel injectors
http://www.dynomitediesel.com/
Old Apr 9, 2006 | 11:33 PM
wcjp's Avatar
Ditto the DDP injectors. Here's the dyno on my bone stock 06' and with injectors only.
Old Apr 10, 2006 | 12:21 AM
yfz450guy's Avatar
how do install them on the stock sticks?
Old Apr 10, 2006 | 12:48 AM
TexasCTD's Avatar
Very Nice! I am impressed.
Old Apr 10, 2006 | 11:13 PM
06inferno's Avatar
WCJP
what hp injectors did u go with?? stock no intake or exhaust?? i your truck a auto or manual?
Old Apr 24, 2006 | 12:21 AM
wcjp's Avatar
I requested 55hp injectors. They ended up as 82hp upgrades. Intake and exhaust are stock from the factory. Still running the factory air filter. Truck is the G56 4x4 Megacab.
Skeetsbo
15
Jul 11, 2010 09:53 PM
Bradleysram
19
May 12, 2009 08:36 AM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
atc250r
May 12, 2003 02:56 PM
