increaseing rail pressure
Old Jun 8, 2007 | 05:18 PM
Secondrate's Avatar
ok on the tst r49ap standard program how much rail pressure does it ad every step (1-9) you go up on the rail pressure adjustment like 500 psi or 1,000 psi i ask cause i do have stock injectors and do not want to crack them thanks for any help
p.s. i had the r37 (no rail pressure) just got the r49 (w/ rail pressure) i have to tell you its ten times better w/ pressure
Old Jun 8, 2007 | 07:41 PM
wap's Avatar
wap
Just watch the rp guage on your tst. On my truck rp on 3 I could hit 27k+ no problem.
Old Jun 8, 2007 | 10:45 PM
Secondrate's Avatar
was that with your mp-8 or just tst cause today i went out and hit 25 on level four. what is stock 23 so would that mean it goes up in 500 psi increments
Old Jun 9, 2007 | 07:45 AM
wap's Avatar
wap
That was with no mp8. I can make my truck spike to 26k completely stock. I can not answer what the increments are, call tst and see what they say. For dialy drivin it is a good idea to keep it no higher than 25k
Old Jun 9, 2007 | 03:20 PM
zuki_dan's Avatar
On mine I run it at level 2 or 3 depending on the power level. I have never seen my gauge read over 25k at WOT. I also have stock injectors.
Old Jun 10, 2007 | 12:17 AM
XLR8R's Avatar
Don't forget the OEM rail pressure sensor isn't capable of reading values higher than about 27.5K psi
5.9Excursion
Mar 13, 2008 10:56 AM
subspd
Dec 24, 2006 02:01 PM
rjm022
Dec 14, 2006 05:20 AM
mtl0727
Nov 5, 2005 06:47 PM
Mechanos
15
Feb 10, 2005 12:25 AM
