I'd like to see what mpg other Mega's are getting (18.5 on last tank)
Old Mar 27, 2007 | 04:55 PM
MOJO1's Avatar
I quit looking. I wish it got what my JEEP LIBERTY CRD does
Old Mar 27, 2007 | 04:57 PM
beretzs's Avatar
My truck has been averaging over 19MPG hand calculated since I went over 20K miles. Around 10K it leveled out and starting going up slower, but 19MPG is a good truck in my book. I can regularly get over 700 miles per tank outta my truck. I would think with a little programming and opening up the exhaust some I should be able to push it over twenty. Scotty
Old Mar 27, 2007 | 05:10 PM
RJOS's Avatar
I just got almost 20 (19.4) in town back and forth to work. Hand jammed it...really..
Old Mar 27, 2007 | 05:17 PM
jonesm8's Avatar
rustyshakelford,
I'm running the news software mild torque management.
Old Mar 27, 2007 | 05:23 PM
rustyshakelford's Avatar
thanks. mines been stinking. maybe 15ish hwy and the same in the city. i pull my boat and down it goes...ive got the mod trq but ill try the mild
brett
Old Mar 27, 2007 | 05:56 PM
Lrobison's Avatar
I have 1500 miles on my 07 and average 16-18 mpg at 70 -75 mph. My 2nd gen Q-cab (02) was good for 18-21 depending on driving habits.
Old Mar 27, 2007 | 06:05 PM
D.Wiggs's Avatar
I have averaged 16.5 over the first 7700 miles of Optimus' journeys. 15% towing, 70% highway (@ 75MPH) and 15% city.
Old Mar 27, 2007 | 06:08 PM
RocketJohn's Avatar
I'm avg 15.5 without thinking about how I drive... 17 on highway...
Old Mar 27, 2007 | 06:34 PM
OR Mega Cab's Avatar
The best I have gotten is 18.5. 100% highway, cruise set at 64 mph. Overhead reads 2.2-2.7 high on every tank. If I drive the truck like I like to drive , very heavy footed, stoplight racing anyone who is willing, I get about 12.5 hand calc, overhead will say 14.5.
I have 6000 miles on the truck, have been playing with different additives and did notice about a 1-1.5 gain with power services silver. Did not notice much difference with Howes, but the truck is a little quieter.
I am happy if I get 400 miles between fill ups. Fill ups usually take 27-29 gallons. I have not done the tank vent mod...yet.
When I was driving across the desert I drove 85 or so for close to 200 miles and the mpg went down to 11.
This truck is way more temperamental than my 2002. It got about 16-17 mpg no matter what I did to it. This one gets horrible mileage if I romp on it very much.
Old Mar 27, 2007 | 07:19 PM
Valafar's Avatar
17.5 downhill to work and 16 uphill back to the house.
Old Mar 28, 2007 | 02:04 AM
95ram's Avatar
Only three fill ups so far and they were ~14, 16+, and 15.5ish. I hope it goes up.
Old Mar 28, 2007 | 08:26 AM
ColdCase's Avatar
At 25000 miles, keeping it at around 2000 rpm (70mph), tires aired up, unloaded, and above 50 degrees I get 22 mpg. There seems to be a steep mpg cliff above 2000rpm and below say 40 degrees. The worst I got on a tank was 15 mpg in below zero weather with plenty of stop and go and idling. The overhead indicates about 3 mpg lower than actual. Driving is typically 80% highway.
Old Mar 28, 2007 | 09:15 AM
JohnInNH's Avatar
The 6 speed gets worse on the highway especially with stock tires.. the gearing is just to low. Check the high MPG postings and they are usually an auto.
A 6 speed getting 2000 rpm at 70 does not have stock tires. Taller tires help.
I have 14K on my truck.... 20.8 MPG on my last fill up (244 miles) that's using my GV Overdrive and stock tires. Hills and studded tires. I have averaged 18-19 MPG Lowest was 15 some light towing and plowing. I have a log and hand calculate.
G56 with stock tires (SRW) w/o using the splitter I get 16 MPG at 70-75 MPG Using the 22% overdrive I gain 3-4 MPG. (on the highway at 65-72 MPH)
At 75 I start to drop MPG...
This is a 4x4 Standard cab with a ARE cap. 20.8 MPG was using Smarty on #9 Wild Torque Management.
Old Mar 28, 2007 | 09:38 AM
ROOFGOOF's Avatar
My overhead likes to mess with me. At approx. 68-70mph it says 22 mpg But in reality, I was getting around 17. 18 at best on the highway....but I just filled up yesterday and hand calculations show 20 mpg ! Mostly highway and easy on the throttle.
I usually gun it on the on ramps, etc to blow it out then go back to 70-74 mph. I have 5200 miles so far.
All stock with a Leer cap.
Old Mar 28, 2007 | 09:41 AM
groran's Avatar
I'm not a mega...
But I'm averaging 18.6 babying it, shifts at 1700 & 17.7 stepping shifting at about 2k, all hand calculated with 2k miles on it, man I love this truck
Polaraco
Jun 1, 2011 12:16 AM
tmleadr03
Dec 24, 2007 10:01 PM
89dieselkong
May 19, 2006 09:19 PM
Mcmopar
May 11, 2006 02:17 PM
