How much smoke with the Juice and Attitude?
Just like the title says
How much smoke (if any) will I get running the Juice with attitude?
I will have a FP and RP gauge installed too so I can monitor pressure but other than that can I run on all settings of the J w/ A?
madhat's monkey boy...
It will be OK for the smoke. You need to set it to 5 on the low boost fueling but my truck smoked 5x better with the Bullydog. If your objective is to black out intersections, it will not do it.
I put mine on level 4 and the low boost on 5, lock the converter, and roll into it about 1/4 throttle just haze tailgaters...its not a ridiculous cloud but its a good fog...
Like others said of you run on level 5 with low boost fueling set on 5 also it will smoke decent - just nothing overly spectacular. The HOT unlock might help a little more. As for how everything else will appreciate it... might want to save some dough for a clutch and I would keep a close eye on fuel pressure. You'll be walking the line on a stock lift pump.
Thanks all. I wouldn't mind smoke from time to time when the tailgators or slow people are on the roads..... I just put the RP and FP gauge in about an hour ago so we'll keep close tabs on that.
I probably won't run on level 5 all the time but it'd be nice to play once in a while. Fuel system is next on the list. Then probably clutch.
I tow 8-9k lbs about 2 times a month. I'm guessing level 2 or 3 for towing.
TN_diesel
30
12-18-2008 11:27 PM
5.0 Mustang Man
10-21-2008 02:50 PM
tvanry
06-09-2008 02:25 PM
tvanry
05-29-2008 09:17 PM
Common
03-29-2008 10:26 AM
