How much psi with Smarty?
Old Sep 27, 2006 | 05:30 PM
  #46
973604x4's Avatar
Originally Posted by XLR8R
How long did you run it? How high did your boost get?
"According to Quad I should have been able to get 40+" using the race box
its agreed stock psi is 32.
Old Sep 27, 2006 | 05:35 PM
  #47
qzilla's Avatar
Originally Posted by morkable
So Quad if I understand this correctly, I am running a 03 with a sps 6280, and if I am not mistaken the little screw that I adjust to raise the boost will basically do the boost fooling for me ( i realize that the juice does this too, but right at this moment I have it out of my truck)
Kevin
If you run over about 23-24psi then you should set a code if you removed your Juice. The truck will also typically de-fuel. Now on a heavily modified truck it is only going to de-fuel so much but there should be some reduction in power.
The little screw should just be adjusting the wastegate or something else on the sps6280, I am not sure exactly what screw you are talking about though.
Old Sep 27, 2006 | 05:37 PM
  #48
qzilla's Avatar
Quad,
Does the Quad Race have boost fooling or is that something extra?
Yes all of our modules do boost fooling even in the "off" position.
You should peak at around 44psi here in TX with a Race module.
As far as I know all the current plug in modules (TST, Juice, VA, TS, etc.) do some sort of boost fooling. I am not sure if they all do it in the stock setting though.
Quad
Old Sep 27, 2006 | 05:41 PM
  #49
wap's Avatar
wap
I got 44lbs with my quad race.
The TS mp8 does boost fooling in the off position too, and I have had 44-45lbs with it also.
Old Sep 27, 2006 | 07:24 PM
  #50
XLR8R's Avatar
Thanks Quad - I like that the Race box has boost fooling even when it's in the off position. Any idea what psi my '05 would peak at like that?
Also, I asked this of Bob & Marco too: do you recommend the RokTech sensor (which advances timing) to be safe to run with the Race box, which I assume also makes some of it's power through advancing (as well as increasing the duration of) the timing?
Old Sep 27, 2006 | 07:42 PM
  #51
wap's Avatar
wap
Look at my last post, you will get 44lbs. +- 1, maybe
I ran the rok, it worked with the race box but my tst can do 18 degrees of timeing and I dont think it is necessary for me anymore.
Some can run it, others cant, all trucks are differant, if it rattles do much back it down.
Old Sep 27, 2006 | 09:53 PM
  #52
morkable's Avatar
lol,, yeah the wastegate screw,, thats the ticket,, man I hate it when I have a moment,, lol
Kevin
38 Cigarette
16
Aug 28, 2015 11:27 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
