How much EGT cooling can I expect?
Old Apr 27, 2009 | 02:49 PM
FBs555CTD's Avatar
I have a mostly stock '04 (see sig). I can get to ~1300 peak on the EGT with Smarty on 5 (no adjustments to standard REVO catcher 5).
How much cooler can I expect to run if I get a boost elbow and set the turbo to ~30psi? I currently max out at about 23.
What would you expect my peak EGT to be if I upgrade to a HE351 turbo (from a '05 truck) and set it to ~40psi peak?
I'm wondering if I need to upgrade to the HE351 to keep my EGTs cool with the Smarty on 5. I can upgrade to a nearly new HE351 for $300. Would I be better off spending that money on an intake or exhaust?
FB
Old Apr 27, 2009 | 03:08 PM
jdwest's Avatar
I run my Smarty on 5 with stock TM and max timing...I have to push it HARD on a hot day to get to 1200 degrees running around empty. I'm pretty happy with the setup. Trust me, if my clutch would hold it I'd turn it up a little more.
Old Apr 27, 2009 | 05:57 PM
jgiachino's Avatar
i'm not sure on the 04, but i know the 04.5+ 1300* is nothing to be concerned about at all...maybe diff for your year....
Swaping to the bigger turbo will raise cruise egt's slightly and reduce more agressive throttle egt's...
Again, not an 04 expert, but on the 04.5+ trucks an $80 muffler swap will help witht egt's as will a $60 drop in air filter....
If you can swing all three for around$450, you'd definately enjoy excellent egt's....
powerrammaster
Jul 17, 2008 06:42 AM
91rangerturbo
31
Apr 3, 2008 07:49 AM
trades2much
Oct 25, 2007 03:42 AM
jeeptjstud
16
Mar 22, 2006 02:43 PM
Cumminsdieselboy
Feb 4, 2003 07:04 AM
