How much boost to HE351
Old Jan 6, 2009 | 05:55 PM
ratsun's Avatar
Going to swap out my 341 for a 351 and while its on the bench I am going to tap out the housing for an adjustable elbow, wondered what can I run this thing up to with out getting into to much trouble?
Old Jan 6, 2009 | 06:03 PM
chadder1313's Avatar
Ive seen 42 psi on more than one occasion. I would not go above 42 psi.
Old Jan 6, 2009 | 07:04 PM
UNDER-PRESSURE's Avatar
I run 40 psi with mine.
Old Jan 6, 2009 | 07:26 PM
soulezoo's Avatar
DTR 1st Sergeant
Over 40 is inviting overspin and early failure... in any case, even if it does not do that, it is out of the compressor map and blowing very hot air... which = no power gained.
Old Jan 6, 2009 | 07:29 PM
ratsun's Avatar
Ok thanks guys, I will try to set it around 36-38 psi for fun and see how it goes.
Old Jan 6, 2009 | 11:01 PM
Syndicate's Avatar
I have seen 42 PSI for the last 90 000 kms on a daily basis. You would think I stole my truck by the way I drive it!
Old Jan 7, 2009 | 09:52 AM
XLR8R's Avatar
I run the HE351 up to 48psi many times - takes a lot of drive pressure, but it's still pulling hard.
Don't expect it to last forever with that abuse.
CRToney
0
Nov 26, 2014 07:55 PM
crewcabxlt
Jun 18, 2009 01:15 PM
1985cucv
Mar 22, 2009 07:32 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
