How long should it take to replace turbo?
Looks like I'll be doing this myself and it doesn't look like it will be too bad. Is there anything I need to look out for or be prepared for?
If you can't do it in less than an hour, just give up
Oh wait, I've done it a dozen times, so
Make sure you get it "clocked" correctly, and run some oil into it before you start it, and all will be fine. Not a hard job, but some of the bolts on the newer trucks are harder to get to than on mine.
I could tell you all the tools you'd need if you had a 2nd Gen
Good Luck,
Chris
.Oh wait, I've done it a dozen times, so
Good Luck,
Chris
There are gaskets between the manifold, you dont have to pull the manifold,its more of a pita.
If its a II 66 OR 62 there easy to change - the Bd super B is a pain.
I only used box end cheap wrenches the thinner the better for getting at the rear nuts 1.5 to 3 hrs you should be done.
It is a BD Super B turbo....
Thanks for the input everyone. I just hate to start something without some idea of what I'm getting into. It can't be any worse than a 2 day install of headers in my old LT1 Trans Am or the 8 hour spark plug change.....
If I did pull the manifold off, is the gasket reuseable or will I need a new one? Also, I have little girl hands so Is it possible to get to those bolts at all that Banshee mentioned?
Originally Posted by banshee
Good luck getting the inside nuts off. You'll more than likely have to pull the manifold to get it off.
Oh ya! And who wants to come by and help??? I'll be putting the FASS on at the same time if there is enough time.....
Chris
madhat
Jan 11, 2015 12:05 PM
PMK
Nov 15, 2010 03:55 AM
mttjma2002
Jun 22, 2009 05:42 PM
zack birge
Dec 5, 2008 02:47 PM
royta
Jul 26, 2004 07:20 PM
