How to?
Old Jul 8, 2008 | 08:06 PM
Angus Breeder's Avatar
How to?
How do you enable the high idle on a 2004.5?
Old Jul 8, 2008 | 08:24 PM
madhat's Avatar
Administrator/Jarhead
Gotta take it to the dealer.
If you got a good one, they'll only charge you .25 hr of labor.
The Smarty may have that function, I don't know for sure...
Old Jul 8, 2008 | 10:26 PM
Billm2004's Avatar
yup smarty has it.
Old Jul 8, 2008 | 10:33 PM
SS1156's Avatar
What's the reason for high idle?
Old Jul 8, 2008 | 10:34 PM
annabelle's Avatar
My dealer did it for free. Tell them you want to warm up the cab quicker. They said (in El Paso?, I said no, when I'm hunting in CO)
Old Jul 8, 2008 | 11:00 PM
PRO-NRA's Avatar
Originally Posted by Billm2004
yup smarty has it.
I don't think so or at least not on an S06 Smarty. This is a dealer enable program. If you have an auto then that is all you would need but if you have a manual your have to do more like clutch safety switch or grounding Pin #22 on the ECM. If you have a manual, I have the instruction I used for my 06. PM me.
Old Jul 8, 2008 | 11:13 PM
annabelle's Avatar
I had to go back twice, as they didn't enable it the first time, only brought up with their scanner, the first time. Enabled it the second time
Old Jul 8, 2008 | 11:17 PM
GlennRMK's Avatar
Put the money the dealer would charge you towards a SMARTY!
Old Jul 8, 2008 | 11:21 PM
annabelle's Avatar
Just put it back to stock with the Smarty before you go in, then they will never know.
Old Jul 9, 2008 | 05:54 AM
checkster's Avatar
Huh.......My smarty enabled it on my 06
Old Jul 9, 2008 | 06:47 AM
Patriot2500's Avatar
The Smarty and my old BullyDog PowerPup enabled high idle.
Old Jul 9, 2008 | 07:29 AM
lmills's Avatar
the smarty will enable it on auto trucks without a problem. It also enables it on the stick trucks, but you have to ground one of the pins on the ecm for it to work.
Old Jul 9, 2008 | 07:38 AM
PRO-NRA's Avatar
Uner what menu on the Smarty? I am not aware of this feature. I've done tire size change on the Smarty but not high idle. I would like to know where on the Smarty for sure to someone that has done it.
Old Jul 9, 2008 | 07:40 AM
MikeyB's Avatar
SMARTY by default enables the high idle. No menu to select.
But you will have to ground ECM pin 22 (PTO enable) for high idle to work with the manual transmission.
MikeyB
Old Jul 9, 2008 | 10:04 AM
rogers259's Avatar
I have a 2004.5 and my smarty enabled high idle, no extra work needed.
