Higher line pressure and resistor install questions...
Old Jul 13, 2006 | 01:02 PM
trik396's Avatar
Question about higher line pressure and resistor install
My trans guy is going to install a new spring in my valvebody to increase line pressure so I don't frag my clutches. I know I need to install a electrical resistor to stop the ecm from freaking out. My guy said it may be best to install it at the trans instead of in the engine compartment.
What do you guys suggest (location)?
And what are some pressure suggestions? 150psi or closer to 200psi?
And at the higher end, he said he would worry about fragging the oil pump (possibly)...? or possibly lessening it's lifespan.?
Old Jul 13, 2006 | 02:41 PM
Timinva's Avatar
DTR Advertiser
You should not need a resistor on a 48re. I have built about 20 48re transmissions and have never needed a voltage regulator/resistor. At 200 psi of line press you will have to worry more about the factory front drum inner seal than the pump. Tim
Old Nov 14, 2008 | 01:48 PM
MiB's Avatar
MiB
How much line pressure will be ok to the factory front drum seal?
Where ón the trans do you check the pressure.
I think i go with low pressure, because i dont feel that it shifts firm.
I have also notice that my dtt tc slips a second or two when i floor the pedal.
Mike
Old Nov 14, 2008 | 06:27 PM
no_6_oh_no's Avatar
Doesn't matter what line pressure you run, there are NO line pressure sensors on a 48RE. The only pressure sensor there is measures gov pressure.
If the builder does not do the VB correctly, the line pressure will flood the governor pressure circuit and trigger codes. Then you need a resistor and other fixes cuz it messess up the shifts.
Old Nov 15, 2008 | 04:24 PM
mopardamo's Avatar
Hello,
If you are talking about the trans in your sig then give Dave a call before any one else does anything.
Damon
Billut
Feb 27, 2014 09:07 AM
1985cucv
Feb 20, 2010 09:15 AM
haftrek
Oct 7, 2009 11:20 PM
greenwing
Dec 19, 2007 08:18 PM
jerry007
Oct 28, 2004 08:24 AM
